**Help Valve cover bolts keepin spinning when loosening**
Old Oct 14, 2006 | 12:15 PM
Esdelota's Avatar
Default **Help Valve cover bolts keepin spinning when loosening**
^ yea i tried to remove 1 of the bolts on the valve cover and they jst keep spinning....wat should i do to remove it...thanks
Old Oct 14, 2006 | 12:20 PM
NMZ's Avatar
NMZ
Default Re: **Help Valve cover bolts keepin spinning when loosening** (Esdelota)
just pull it
its obviously stripped
Old Oct 14, 2006 | 02:38 PM
Esdelota's Avatar
Default Re: **Help Valve cover bolts keepin spinning when loosening** (dontgivafuk)
yea that didnt work
Old Oct 14, 2006 | 03:16 PM
labatt50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dontgivafuk &raquo;</TD></TR><TR><TD CLASS="quote">just pull it
its obviously stripped</TD></TR></TABLE>
or snapped!
Old Oct 14, 2006 | 07:55 PM
Esdelota's Avatar
bump any suggestions
Old Oct 14, 2006 | 10:32 PM
12secEG's Avatar
it's probably stripped, take it off and re-tap it again and put a new one in.
Old Oct 14, 2006 | 10:36 PM
Tzer's Avatar
If you can get something under the head of the bolt, Say a Screwdriver, you can try to apply upward pressure while loosing the bolt.
Good Luck.
Old Oct 17, 2006 | 06:44 PM
Esdelota's Avatar
Default Re: (Tzer)
bump tried alot of thngs...no luck...wat can be the problem?
Old Oct 17, 2006 | 06:51 PM
myJDM89EF's Avatar
Default Re: (Esdelota)
i was taking off my valve cover like 2 hours ago and had the same thing happen, i just pryed them out with a screwdriver and they were fine
Old Oct 18, 2006 | 05:44 AM
Esdelota's Avatar
Default Re: (myJDM89EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myJDM89EF &raquo;</TD></TR><TR><TD CLASS="quote">i was taking off my valve cover like 2 hours ago and had the same thing happen, i just pryed them out with a screwdriver and they were fine </TD></TR></TABLE>
damn wish i had the luck...tried that didint work
Old Oct 18, 2006 | 05:50 AM
0334973's Avatar
you done need to completely remove the bolts for the cover to come off. as long as you can pull them upwards a bit the cover will come off
schwinnrex
11
Apr 7, 2007 12:01 PM
Elmo1968
12
Oct 7, 2005 08:31 AM
EJ8 GSR-T
16
Nov 12, 2004 09:22 PM
Type_Rydah
Dec 27, 2003 01:12 AM
SL!M
Apr 26, 2003 09:06 PM
