JDM ITR cat or aftermarket high flow cat?
I ahve a dc4. I just recently picked up a JDM ITR header and ahve a S2 2.36" exhaust. But the question is will a JDM ITR cat flow just as good as a carsound 2.5" univ. cat. Im assuming carsounds measurements is for the outer diameter same with the JDM collector size. But which to get. Id get the JDM cat from passwordjdm or inlinefour. if i get carsound which model will i need? 2 o2 bosses or just one? I want the 2.5" and Ill find flanges and have my friend weld them in place. or just get JDM and have a bolt-on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 »</TD></TR><TR><TD CLASS="quote">I ahve a dc4. I just recently picked up a JDM ITR header and ahve a S2 2.36" exhaust. But the question is will a JDM ITR cat flow just as good as a carsound 2.5" univ. cat. Im assuming carsounds measurements is for the outer diameter same with the JDM collector size. But which to get. Id get the JDM cat from passwordjdm or inlinefour. if i get carsound which model will i need? 2 o2 bosses or just one? I want the 2.5" and Ill find flanges and have my friend weld them in place. or just get JDM and have a bolt-on. </TD></TR></TABLE>
I'd suggest getting a bolt-on high-flow cat from SMSP. The JDM cat will not fit your setup without modification, and the SMSP cat will flow better.
