Crank pulley issues !!
Old Oct 14, 2006 | 05:43 AM
wheelmaneg6's Avatar
Default Crank pulley issues !!
I changed crankshafts on my 97h22 to a 92-96 crank because after taking it apart and found a spun bearing i got the block machined and found a used crank , my 97 crank bolt is too big for the 92-96 so i used the 92-96 crank bolt and the crank pulley is touching the timing case and rubbing it badly. If i am using the 97 crank pulley with the 97 timing case and i have a 92-96 crank, what pulley should i use to stop the rubbing of the timing case?
Old Oct 14, 2006 | 05:49 AM
Revi's Avatar
Default Re: Crank pulley issues !! (wheelmaneg6)
Im not sure but the 92-96 crank might not be the same lenght as the 97. You might want to try the 4th gen pully and see what happens.
Old Oct 14, 2006 | 08:34 AM
fastludeh22's Avatar
ya im glad u didnt try to force the 97 bolt in the a1 crank. i think they have different theards, but i know they are not interchangable. ive used both cranks and pullys, but i dont have a timing cover...did u reinstall teh littel spacer thing on the back, as well as the balance shaft pully? ill look later at both pullys and see if i see a difference
Old Oct 14, 2006 | 09:38 AM
h22 civic's Avatar
Default Re: Crank pulley issues !! (fastludeh22)
their are 2 sized bolts the jdm ones are thicker also if i remember rigght the 92-95 usdm are smaller and the 97- are thicker all jdm are thick
Old Oct 15, 2006 | 08:25 AM
MecUneek's Avatar
92-96 mains are 50mm
while 97+ mains are 55mm....
unless I am mistaken... think you will run into big problems there...
Old Oct 15, 2006 | 04:06 PM
Default Re: Crank pulley issues !! (MecUneek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MecUneek &raquo;</TD></TR><TR><TD CLASS="quote">92-96 mains are 50mm
unless I am mistaken... think you will run into big problems there... </TD></TR></TABLE>
close but wrong, 98+ are 55 mains...97 a4 is the only a4 with 50 mm mains
Old Oct 16, 2006 | 06:16 AM
flyrod's Avatar
Is the lower timing cover installed correctly? Do you have all of the propper gears, washers on the crankshaft under the pulley?
chope045
Mar 30, 2011 11:16 AM
97Prelude_SH
Nov 19, 2009 06:17 PM
97Prelude_SH
Oct 31, 2009 07:16 AM
