Transmission help
Old Oct 13, 2006 | 11:29 PM
lowered94accord's Avatar
Default Transmission help
...well im dropping my automatic transmission out of my 1994 Honda Accord Ex..and Im needing some help...ive taken out the axles..passengers side radius rod, starter, wiring harness and all the works..i unbolted 5 bell housing bolts and im not sure if there is anymore..i also already unbolted the coolent lines connected to the tranny..i was wondering if there could be some sort of another bolt holding the transmission to the motor..i took off the torque converter plate and all 8 bolts inside...can anyone tell me if im missing anything or give me a better guide to dropping the transmission than the ones on here..or maybe some pictures..anything will help thanks..ive used the search button for the past 30 minutes and came up with nothing..thanks
Old Oct 14, 2006 | 06:02 AM
standbackimapro's Avatar
Default Re: Transmission help (lowered94accord)
Transmissions are a pain in the *** to get off
Theres Guide pins that stick into the side of the motor,
You might have to Hit it kick it, to get it off
I pulled a whole motor and trans out of a 90 accord, and we had it laying on the ground, all the bolts were out, and we were hitting kicking pushing this thing and it wouldnt come off
Eventually we got a screwdriver and a hammer and pryed it apart...
Old Oct 14, 2006 | 01:20 PM
ap1kindaguy's Avatar
Default Re: Transmission help (standbackimapro)
ok thanks..does anyone know exactly how many bell housing bolts there are..i got 5 off and thats all the ones I see but im not sure..im afraid to kick it cuz the only thing holding it up is the jack cuz im not dropping the motor out just the tranny..i guess ill try the screwdriver and hammer approach lol...wish me goodluck if anyone else has any suggestions please fill me in! thanks
Old Oct 14, 2006 | 01:31 PM
stinker504's Avatar
I'm pretty sure there are only 5 bolts after removal of the starter. On my accord they use one starter bolt that goes all the way through to the engine.
There are two dowel pins that keep it stuck on there. Just take your time and be careful.
Old Oct 14, 2006 | 03:16 PM
Thats the only thing i can think of, Those Dowel pins hold it on there pretty good,
Old Oct 15, 2006 | 10:36 PM
Default Re: (standbackimapro)
well thats one problem ive had..i cant get the starter out..seems like there is to much **** in the way...i have both bolts out but they are to long to pull all the way out and i cant get the damn thing loose..any ideas on this?
pdub1474
Jul 19, 2018 12:27 PM
slowLSTek
Transmission & Drivetrain
Apr 13, 2011 10:44 AM
SIRIUS VTEC
Aug 24, 2010 10:49 AM
jwshilli
Feb 5, 2008 10:50 PM
