Integra rear sway bar Question?
Old May 3, 2002 | 04:39 PM
wronghand's Avatar
Default Integra rear sway bar Question?
I have a two part question.
1. Will the 90-93 rear sway bar fit on 4th generation civic/crx?
2. What size is the 2nd generation rear sway bar?
Thanks in advance for your help.
Old May 4, 2002 | 03:13 AM
wronghand's Avatar
Default Re: Integra rear sway bar Question? (wronghand)
Anyone have any ideas on this? Someone has to have tried it.
Old May 4, 2002 | 05:22 AM
Ham'ed Hatch
Guest
Posts: n/a
i had a 91 integra rear sway bar on my 90 DX hatch. with the 4th gen sway bar mounts (Si), the sway bar will bolt straight on.
not sure the exact mm size, but it was bigger/fatter than my friends stock Si bar.
Old May 4, 2002 | 09:27 AM
JOSEPH's Avatar
Default Re: Integra rear sway bar Question? (HoMoCo FoLife)
the 90-93 integra swaybar is the same size as the 88-91 crx si swaybar. it does not bolt on cause of the mounting bracket
Old May 4, 2002 | 01:32 PM
wronghand's Avatar
Default Re: Integra rear sway bar Question? (JOSEPH)
I have a CRX DX. I have custome brackets for the rear sway bar. Will it bolt up to the Si LCA's? And if so is it any bigger than the 15mm Si?
Old May 4, 2002 | 08:27 PM
Ham'ed Hatch
Guest
Posts: n/a
yes it will bolt to Si LCAs. and i'm thinking it's 18mm...not 100% sure on the thickness.
but i DO KNOW it's thicker than the Civic/CRX Si's...don't listen to JOSEPH up there...damn newbie.
Old May 4, 2002 | 08:42 PM
wronghand's Avatar
Thanks man. I thought it would probably bolt up since the two cars on based on the same chasis. I was just curious about the size difference. Now all I need is a teg rear sway bar and the smaller HF front sway bar and I will be in business.
DoubleDirtyC
Aug 17, 2010 09:18 PM
lowbOOsted
Dec 5, 2005 05:37 AM
Serdar
Apr 22, 2005 04:45 AM
ThefirstPACT
22
Feb 8, 2005 11:42 AM
chadmasterc
Nov 24, 2003 11:21 AM
