4th Gen Lude suspension reassembly
Old Oct 13, 2006 | 09:51 PM
MadCityLude
Guest
Posts: n/a
Default 4th Gen Lude suspension reassembly
I just have a couple quick questions (should be easy for some of you)
This first pic - what is this called? I am missing the bushings for it and need to order new ones, but dont know what to ask for.
This pic here is showing a (ball joint??) what is it called for sure? Why won't it fit back together tight? I was reassembling and it just spun inside the rubber boot thing. Now I cant get it tight. - same thing on other side.
Old Oct 13, 2006 | 10:08 PM
98vtec's Avatar
moderator emeritus
Default Re: 4th Gen Lude suspension reassembly (MadCityLude)
sway bar endlink
stabilizer (sway bar) link per Helms
If they are frozen, you will likely need to replace the joint.
Old Oct 13, 2006 | 10:12 PM
Hawkze_2.3's Avatar
First one is a front swaybar endlink and the 2nd looks like maybe a tie-rod and but I can't tell where it is.....
Old Oct 13, 2006 | 10:13 PM
98vtec's Avatar
moderator emeritus
Default Re: 4th Gen Lude suspension reassembly (Hawkze_2.3)
btw, are you working on your car in the dirt?
Old Oct 13, 2006 | 10:18 PM
MadCityLude
Guest
Posts: n/a
Default Re: 4th Gen Lude suspension reassembly (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">btw, are you working on your car in the dirt?</TD></TR></TABLE>
No it is sitting in my Driveway right now. I am not working on it right now, I had to pull my other lude in the garage for a few days.
Old Oct 14, 2006 | 06:50 AM
roller3804's Avatar
yeah ull have to replace the ball joint. The only way to get it back on is with an impact gun in small short bursts...This has happened on two rsx's ive worked on. But you might as well just replace it.
Old Oct 14, 2006 | 11:39 AM
Rocket Man's Avatar
Default Re: (roller3804)
Get an allen wrench, stick it in the end of the bolt in the hole made for it. Then hold the allen wrench while you tighten the nut back up....
Enzo15
May 12, 2014 08:04 AM
EG2Driver
May 25, 2006 03:47 PM
snyderman5
Mar 2, 2006 04:55 PM
Tbone
13
Jun 26, 2005 04:32 PM
Targa250R
Suspension & Brakes
10
May 10, 2005 02:00 PM
