have trouble starting when gas is on low... (yes, I know it sounds retarded)
Old Oct 13, 2006 | 08:31 PM
andylawcc's Avatar
Default have trouble starting when gas is on low... (yes, I know it sounds retarded)
I just got a 99 EK sedan. When gas on low, it takes a long time to start the engine... as if it seems like the car have troubing pumping gas from the gas tank to the engine.
but this problem did not exist to my previous car nor my company's truck.
is my fuel pump dying? or there's something else?
Old Oct 13, 2006 | 08:33 PM
pdiggitydogg's Avatar
every honda ive ever driven does the same thing
it would start right up if you turn the car to "on" for ~3seconds before turning it further, to "start"
Old Oct 13, 2006 | 08:59 PM
nighttrain33's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">every honda ive ever driven does the same thing
it would start right up if you turn the car to "on" for ~3seconds before turning it further, to "start"</TD></TR></TABLE>
Thank God, I thought it was just me. Actually I figured it's 'cuz I drive a Honda. But I'm glad I'm not the only one.
-Shane
Old Oct 13, 2006 | 09:06 PM
Bond's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
yes it needs time for the pump to build fuel press.... there small pumps so it takes a second or two....basically wait for the main relay to switch over (you'll hear it) and then start it. and yes the less gas you have the longer it takes to build sufficient fuel press.
Old Oct 13, 2006 | 09:15 PM
andylawcc's Avatar
Default Re: (Bond)
okay... thanks all. can I slap a VtecH sticker on the fuel pump to make it work faster?
Old Oct 13, 2006 | 09:18 PM
Bond's Avatar
Default Re: (andylawcc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andylawcc &raquo;</TD></TR><TR><TD CLASS="quote">okay... thanks all. can I slap a VtecH sticker on the fuel pump to make it work faster? </TD></TR></TABLE>
depends on what kinda mhz your dealin with.... don't wanna blow anything up....should be ok with a 8000mhz series
Old Oct 14, 2006 | 05:03 AM
Mr.Lude's Avatar
Default Re: have trouble starting when gas is on low... (andylawcc)
Hmmm maybe...YOU NEED TO PUT GAS IN IT! Thanks.
jdmmanek
19
Jul 20, 2009 06:16 PM
menappi
Jun 21, 2006 04:01 PM
LvN
19
Jun 8, 2006 06:58 AM
tommy.
Mar 23, 2006 07:13 PM
SiMateoAko
16
Aug 17, 2005 05:35 AM
