H22 crank pulley help!!!!
Old Oct 13, 2006 | 07:51 PM
wheelmaneg6's Avatar
Default H22 crank pulley help!!!!
I changed crankshafts on my 97h22 to a 92-96 crank because after taking it apart and found a spun bearing i got the block machined and found a used crank , my 97 crank bolt is too big for the 92-96 so i used the 92-96 crank bolt and the crank pulley is touching the timing case and rubbing it badly. If i am using the 97 crank pulley with the 97 timing case and i have a 92-96 crank, what pulley should i use to stop the rubbing of the timing case?
wheelmaneg6
Oct 16, 2006 06:16 AM
spooned out
Aug 26, 2006 08:36 PM
Maddox
May 24, 2004 10:46 PM
