Why is my torque so low?
Just wondering cause my HP seems to be ok, but my torque seems really low compared to others...I don't have a type R, but the only guys i know running toda B cams are from this board.
Here are my results from yesterday's dyno
corrected:
uncorrected:
What do you guys think? Stock GSR manifold, stock ecu...hopefully theres power to be unleashed in the future.
corrected:
uncorrected:
stock GSR ecu with Spec Bs or JUNIII will tend run lean after the secondaries open up but definatly nice and flat curve
and remember that GSR intake manifold and head is neither a high end power maker or low end torque producer its in between menat for street driving
if you got money then you should invest in Skunk2 Manifold (more top end power to be found)
those cams need a single runner manifold. (Skunk 2 Intake manifold). If you have a stock ecu how is it reving till 9000rpms.
eg6-itb
12
Feb 29, 2008 09:25 PM
drivfastr
Nov 23, 2003 05:22 AM
