Suspension & Brakes Theory, alignment, spring rates....
need some help asap koni install
Old Oct 13, 2006 | 05:12 PM
SilentHill's Avatar
Default need some help asap koni install
im in the middle of my koni/GC install and i needed to know if intstead of drilling the OEM bump stocks out to 12mm (to fit over the bump on the konis) if i could just leave them and force them over it? i got one bumpstop over it already, no problems etc it slides up and down (under that bump on the konis). is this bad?? or should it be able to move up over the bump. I personally cant see why it would need to the washer and the top hat sit over the bump and use it as a place to mount right?? i just wanna make sure im not gonna ruin my shocks
Old Oct 13, 2006 | 05:18 PM
SilentHill's Avatar
Default Re: need some help asap koni install (SilentHill)
basically if u can fit the oem bumpstop on the koni without drilling it out is this bad??? has anyone done it
Old Oct 13, 2006 | 05:46 PM
no_money2supe's Avatar
Drilled or not, it doesn't really matter. As you said, the washer above will keep it on anyway. Besides, if your car bottoms out thus requiring the use of the bumpstops, there'll be enough weight from the car to force the bumpstops up. So, long story short, don't worry about it, though I DID drill mine out.
Old Oct 13, 2006 | 05:49 PM
SilentHill's Avatar
Default Re: need some help asap koni install (no_money2supe)
thanks i feel better now know i wont have to re do that corner or buy a 12 mm drill bit, i just cant get the damn brake line brackets off now
Old Oct 13, 2006 | 07:12 PM
EK k kay's Avatar
I didn't drill mine out and they slid in quite easily.
Old Oct 13, 2006 | 07:56 PM
CRX Lee's Avatar
You are not supposed to drill out the bump rubber, just slide it onto the shock rod. If it resists going over the welded ring on the rod, just grip the bump rubber and twist it slightly while pushing it down over the ring. I have done so many installs of Konis on Hondas and never thought of drilling out the bump rubbers. It simply isn't needed, the smaller ID of the foam bump rubber stretches over the rod and holds te bump rubber in place.
The only thing that you are supposed to drill out is the top of the dust cover. Your stock shock rod is 12mm on the working part of the rod where the bump rubber lives once installed just like the Konis. Only the top of the upper pin on the Koni was increased from 10mm to 12mm.
Old Oct 14, 2006 | 12:12 AM
SilentHill's Avatar
Default Re: need some help asap koni install (CRX Lee)
ok thanks i got my front right in but theirs not much i can do in the dark with only a cell phone and flashlight for light. im starting the rest first thing tomorrow morning. Thanks for the help so far .... ill probably have questions about the two rears tomorrow
Ron454321
Suspension & Brakes
May 13, 2011 05:49 AM
lsBlaxican707
Suspension & Brakes
15
Jan 11, 2009 05:50 PM
bopbop93030
Suspension & Brakes
Nov 23, 2008 01:57 PM
square_1
Jun 7, 2008 11:24 PM
DLudist
Suspension & Brakes
20
Mar 2, 2006 10:50 AM
