Acura Rsx Headlight Bulb Installation!!!!!!!!!!~!!!!!!
Anyone know how to install a pair of headlight bulbs into the rsx headlight there is not soo much room to work with. Let me know ASAP!
i had a hid kit on mine and i found it easiest to loosen the head light bracket on the bottom and side. that helps make it a lil more moveable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dC5type_S »</TD></TR><TR><TD CLASS="quote">Its really hard to get a bulb in cause its such a tight squeeze. The easiest way is to remove the front bumper and headlights all together. </TD></TR></TABLE>
What? Thats crazy! I can do both sides in about 5 mins. On the drivers side, the washer bottle tube slides up an over, and on the pass side, the power steeing fluid bottle moves out of the way, then you have more room.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">
What? Thats crazy! I can do both sides in about 5 mins. On the drivers side, the washer bottle tube slides up an over, and on the pass side, the power steeing fluid bottle moves out of the way, then you have more room.</TD></TR></TABLE>that sounds alot better...
removing bumper and headlight is mostly if you want hid's..cuz you need a place to put the ballast somewhere, and the only place is in the bumper place.
DO NOT use sylvania silverstar bulbs!!!!!
I found out the hard way. I bought a pair, put them in, and a few months down, one blew out. Figured it was a bad batch or something, got a replacement, not a week later that one blew out. I luckily bought it at wal-mart, so they gave me a replacement. Then the other side blew out, followed a few weeks later by the newly replaced one.
I had wasted so much money, I just bought the cheap ones. They've been going strong for almost a year.
After this whole ordeal, I talked to a friend who has an RSX & he said he had the same thing hapen to him. He asked the dealership and they said that RSX lights run a little more wattage through the bulbs to get more light, and for some reason the silverstar bubls can't take it.
If anyone else has tried a set of higer-end 'super white' bulbs that have worked well, please share. I liked how the silverstars looked, but they don't last for **** in our RSX's!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvtec95 »</TD></TR><TR><TD CLASS="quote">DO NOT use sylvania silverstar bulbs!!!!!
If anyone else has tried a set of higer-end 'super white' bulbs that have worked well, please share. I liked how the silverstars looked, but they don't last for **** in our RSX's!</TD></TR></TABLE>
truth...im on my 2nd silverstar blub. im just gonna get HIDs soon im tired of replacing them.
SoHc Ej1
10
Jul 15, 2007 06:29 PM
