what can i expect from hx rims
Old Oct 13, 2006 | 01:20 PM
turnsignalandy's Avatar
Default what can i expect from hx rims
If I put HX rims on my ej8, can i really expect to notice any improvements on overall perfrormance?
Old Oct 13, 2006 | 01:27 PM
pat92si's Avatar
Default Re: what can i expect from hx rims (turnsignalandy)
not unless you put a nice set of rubber on them.
Old Oct 13, 2006 | 02:24 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">If I put HX rims on my ej8, can i really expect to notice any improvements on overall perfrormance?</TD></TR></TABLE>
Not really. The car will have 24lbs total less unspring and rotational weight than with the stock 14x5.5" steel wheels. That's the only difference. You may notice marginal improvements, mostly in braking and off-line acceleration. Don't expect anything drastic.
Old Oct 13, 2006 | 04:08 PM
aZnjCC's Avatar
you'll also notice that your front wheels won't be able to move if you have an EX
Old Oct 13, 2006 | 04:11 PM
ballerchild's Avatar
expect to be in the low 12's.
Old Oct 13, 2006 | 06:32 PM
DC_RaceR's Avatar
Default Re: (ballerchild)
Should generate atlease 12 Hp to each wheel due to a lighter wheel...
Old Oct 13, 2006 | 06:41 PM
Default Re: (DC_RaceR)
huh?
Old Oct 13, 2006 | 06:58 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">Should generate atlease 12 Hp to each wheel due to a lighter wheel... </TD></TR></TABLE>
Dude, don't confuse him lol.
Old Oct 13, 2006 | 07:01 PM
suspendedHatch's Avatar
Default Re: (Eran)
No effect on times or mpg.
On bumpy roads, it will feel as though you have premium struts.
Old Oct 13, 2006 | 07:02 PM
94JDMcivic's Avatar
What size are they? I have a set of 13 inch HX wheels, but they won't fix my 94 Civic Ex. If you plan on buying some, check to see if they fit.
Old Oct 13, 2006 | 07:17 PM
cambopheonix56's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">No effect on times or mpg.
On bumpy roads, it will feel as though you have premium struts.</TD></TR></TABLE>
Ligher rims = less rotaional mass = lower times. Might not be much, tho.
Old Oct 13, 2006 | 07:39 PM
deadline's Avatar
14in=HX VX=13in
Old Oct 13, 2006 | 07:59 PM
Default Re: (deadline)
ya the 13 inch ones are not HX they ar VX. Anyway im just askin cause i heard many different stories and opinions on the subject. thanks for posting.
Old Oct 13, 2006 | 08:09 PM
Targa250R's Avatar
be professional
Default Re: (aZnjCC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC &raquo;</TD></TR><TR><TD CLASS="quote">you'll also notice that your front wheels won't be able to move if you have an EX </TD></TR></TABLE>
Yeah, that too.
He said he has an EJ8, so it is definitely an EX. He'll need 5mm spacers for the front, or he'll have to grind down the calipers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">On bumpy roads, it will feel as though you have premium struts.</TD></TR></TABLE>
Changing unsprung mass without changing compression damping ftw!
Old Oct 13, 2006 | 08:11 PM
Default Re: (Targa250R)
the 14 in HX rims dotn fit the ej8 front calipers?
Old Oct 13, 2006 | 08:12 PM
Targa250R's Avatar
be professional
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">the 14 in HX rims dotn fit the ej8 front calipers?</TD></TR></TABLE>
Not without a spacer or minor caliper modifications.
Old Oct 13, 2006 | 08:40 PM
thats a good thing to know. thanks.
Old Oct 13, 2006 | 09:31 PM
aZnjCC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">thats a good thing to know. thanks. </TD></TR></TABLE>
yup...just put a spacer on and you'll be golden Here's mine
Old Oct 13, 2006 | 11:47 PM
would i have to put spacer on theback too, in order to even things out. Then i guess i could have a wider stance right?
Old Oct 14, 2006 | 04:04 AM
t0p_sh0tta's Avatar
No.
You don't "need" the spacer up front if you're willing to grind a little bit of material from the caliper.
Don't bother with a spacer in the rear.
edit:
How much did you guys pay for your 5mm spacers?
Old Oct 14, 2006 | 12:38 PM
Default Re: (t0p_sh0tta)
im willin to put spacers in the rear to if it dont cost too much, give my car a wider stance
Old Oct 14, 2006 | 12:46 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">im willin to put spacers in the rear to if it dont cost too much, give my car a wider stance</TD></TR></TABLE>
Why don't you just get aftermarket wheels with a lower offset and a wider width then? If you're interested in a more aggressive look, you're not going to find it with 5.5" +50mm HX wheels and a 5mm spacer.
Old Oct 14, 2006 | 01:04 PM
ya but i dont got the money for some nice after market rims, and i dont wana draw too much attention. Thieves I think the hx rims are perfect.
Old Oct 14, 2006 | 01:18 PM
hondamark35's Avatar
yeah, i agree with the look of HX. stockish but better than steel.
technically you should get better gas mileage... braking and accel should have better numbers, but i doubt you would notice unless you drive it competitively (like autocross)
yeah the calipers, you can just shave those down, cheaper and more sound than spacers.
also, more important than the wheels...is the rubber you put on them. deffinately H rated or better. 195...14 __H/V/W...
Old Oct 14, 2006 | 01:33 PM
Targa250R's Avatar
be professional
Default Re: (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 &raquo;</TD></TR><TR><TD CLASS="quote">also, more important than the wheels...is the rubber you put on them. deffinately H rated or better. 195...14 __H/V/W... </TD></TR></TABLE>
Speed rating has little or nothing to do with actual tire performance.
