Best way to Remove Oil stains off Engine ?
Old Oct 13, 2006 | 09:39 AM
Oregon's Avatar
* B A N N E D *
Default Best way to Remove Oil stains off Engine ?
Ive noticed when i look under the hood, and Lay down on the ground, and look up around the Oil pan, and the tranny, there are alot of Oil Deposits, and hanging oil..
What would i used to clean that off?
I tryed to pressure wash it off, but, that doesnt do anything, the water just ***** up, and makes nasty stains on the driveway..
Anyone ?
Old Oct 13, 2006 | 09:48 AM
Eran's Avatar
HT White Ops
Concentrated Simple Green (Autoparts Stores)
Greased Lightning (WalMart)
Oil Eater (Sam's Club/CostCo)
+ 10 Minutes
+ Pressure Wash
Old Oct 13, 2006 | 10:07 AM
rmcdaniels's Avatar
Default Re: (Eran)
10 gallons of kerosene should get everything off of there. Just pour it all over the engine bay and interior and light it:
FIRE! FIRE!
Old Oct 13, 2006 | 10:27 AM
sql_civic's Avatar
Default Re: (rmcdaniels)
Use any of the products mentioned above. Simple Green works really well and it's environmentally friendly.
Hook your pressure washer up to the hot water outlet for your washing machine. Then, if possible, turn up the thermostat for your hot water heater to 180 degrees.
Steam it clean while wearing safety googles.
Old Oct 13, 2006 | 11:15 AM
mike1114's Avatar
Default Re: (sql_civic)
Funny this thread came up. Two weeks ago an external oil cooler line blew in my car at the back of the block and spewed all 5 quarts of oil ALL OVER the engine bay. It even came out the front of the hood!!
I just keep pouring simple green where I can pour it and spraying with a spray bottle every where else and wiping it down.
Try to saturate whatever your working on so the oil will run to the bottom of the motor, wipe from top to bottom.
I've had to repeat this a few times, cause like I said oil was everywhere. I've spent about 4-5 hours cleaning it. It's almost done, the conduit around the wiring is a bitch cause of its ridges, oil likes to stay in them........
Old Oct 13, 2006 | 11:25 AM
spooneg8's Avatar
buddy of mine used engine degreaser and then pressure washed...turned out pretty good
Old Oct 13, 2006 | 11:55 AM
deryck324's Avatar
break cleaner and liquid lava soap
Old Oct 13, 2006 | 12:08 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (deryck324)
I've had really good luck with Purple Power/Super Clean from Castrol
Old Oct 13, 2006 | 12:20 PM
sorta2's Avatar
foaming engine degreaser or the gel stuff works pretty good just have to let it sit for a litte while
Old Oct 13, 2006 | 12:34 PM
wudini's Avatar
Default Re: (sorta2)
purple power ftw
Old Oct 13, 2006 | 12:37 PM
biotech0123's Avatar
Default Re: (wudini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">10 gallons of kerosene should get everything off of there. Just pour it all over the engine bay and interior and light it:
FIRE! FIRE!</TD></TR></TABLE>
lol.
Old Oct 13, 2006 | 04:17 PM
97civicB18C's Avatar
Default Re: (biotech0123)
i used engine degreaser n that worked pretty good
Old Oct 13, 2006 | 04:49 PM
Oregon's Avatar
* B A N N E D *
Default Re: (97civicB18C)
Thanks guys, I am goona go try this stuff out, right now
Thanks
Old Oct 13, 2006 | 04:52 PM
Sean @ ESG's Avatar
simple green or carb cleaner
Old Oct 13, 2006 | 09:16 PM
Oregon's Avatar
* B A N N E D *
Default Re: Best way to Remove Oil stains off Engine ? (Oregon)
well the Simple green + 10 minutes and a brush, and 180 degree washer, Did the trick..
Now i have this God awful sound when i put the clutch peddle to the ground and back...
Maybe some WD-40 huh ?
Old Oct 13, 2006 | 10:26 PM
bpkmrtoes's Avatar
simple brake cleaner takes most of that stuff out.
Old Oct 13, 2006 | 10:37 PM
ekladybug's Avatar
Default Re: Best way to Remove Oil stains off Engine ? (bpkmrtoes)
simple green gets my vote
Old Oct 13, 2006 | 10:51 PM
labtec's Avatar
Default Re: Best way to Remove Oil stains off Engine ? (ekladybug)
i use some of the "goop" hand cleaner. put some on the tips of your fingers and rub (hehehe). works very well with oil. then some full strength simple green, sit for a few munites, hit it w/ a rag. pow! clean.
hell it even smells nice afterwards
Old Oct 13, 2006 | 11:07 PM
tiNnNy's Avatar
Default Re: Best way to Remove Oil stains off Engine ? (labtec)
simple green is the ****.
Old Oct 17, 2006 | 10:15 AM
Default Re: Best way to Remove Oil stains off Engine ? (tiNnNy)
YES YES IT DOES SiMpLe GrEeN
Old Oct 17, 2006 | 11:19 AM
Timberland237's Avatar
Default Re: (Oregon)
i just finished cleaning out my entire engine bay check out the pics under engine bay clean-up, i used just normal degreaser let it sit and hosed it then wiped by hand. http://www.piczo.com/civcswap
Old Oct 17, 2006 | 11:34 AM
teamsoy1320's Avatar
link doesnt wrk
Old Oct 17, 2006 | 11:48 AM
NJcoupe's Avatar
This stuff works awesome
Old Oct 17, 2006 | 12:11 PM
EK k kay's Avatar
Default Re: (dxcoupe.)
Carb cleaner + simple green.
Old Oct 17, 2006 | 12:53 PM
vtec4lyfe's Avatar
simple green or any other light degreaser
