2000 accord coupe offset for 17"X7 rims
Old Oct 13, 2006 | 08:53 AM
skingfreak's Avatar
Default 2000 accord coupe offset for 17"X7 rims
I did a quick search of archived topics and nothing came up. What is the offset for a 2000 accord coupe V6. Is it 45 or 50? or something else??? i know the bolt pattern is 5X114 thanks in advance!
Old Oct 13, 2006 | 10:03 AM
Crono139's Avatar
Default Re: 2000 accord coupe offset for 17"X7 rims (skingfreak)
+45 is ideal, but you can get away with +42.
Old Oct 13, 2006 | 02:27 PM
skingfreak's Avatar
Default Re: 2000 accord coupe offset for 17"X7 rims (Crono139)
ok, so if im upgrading to 17's i need an offset of 45 and not 50?
Old Oct 13, 2006 | 08:09 PM
rollercosta123's Avatar
18s are better
Old Oct 13, 2006 | 09:08 PM
Crono139's Avatar
Default Re: 2000 accord coupe offset for 17"X7 rims (rollercosta123)
+50 will work fine.
Like I said, you can get away with wheels that have at least a +42 offset. I haven't had any problems with mine yet. They do stick out a tiny bit, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 &raquo;</TD></TR><TR><TD CLASS="quote">18s are better </TD></TR></TABLE>
That is the perfect size for a 6th Gen. I'm not going to lie.
I opted for 17s because of crappy road conditions, the weight, and the cost. Plus, they look fine with nice drop.
Old Oct 14, 2006 | 02:28 AM
typhoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">I did a quick search of archived topics and nothing came up. What is the offset for a 2000 accord coupe V6. Is it 45 or 50? or something else??? i know the bolt pattern is 5X114 thanks in advance!</TD></TR></TABLE>
I measured some 6th gen alloys and they look like 50mm to me.
Old Oct 16, 2006 | 03:13 PM
skingfreak's Avatar
Hey thanks for the pic, thats a nice looking car but i wont do a drop, the winters where im going to college are brutal, so ill put some winter tires on the stock alloys. So 17's look fine correct? and i maintain the same turning radius correct?
Old Oct 16, 2006 | 05:16 PM
SlowCG's Avatar
here is my car with 18's, my offset and everything is in my sig
Old Oct 17, 2006 | 02:57 PM
skingfreak's Avatar
Default Re: 2000 accord coupe offset for 17"X7 rims (98AV6205HP)
looks good, and you dont have any trouble with your turning radius? also where did you order those from? and how much were they&gt;
Old Oct 17, 2006 | 04:35 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 &raquo;</TD></TR><TR><TD CLASS="quote">+50 will work fine.
if you replacing something with the same width with lower et
let's say 50 oem with 35(new) your rims will stick out 15, not the other way around.
the only way i could think this is true in your case is that your width of your rims is wider than oem, so they bump up the ET/offset.
5zigen looks great
Old Oct 17, 2006 | 04:38 PM
Crono139's Avatar
Default Re: 2000 accord coupe offset for 17"X7 rims (iam7head)
Wheels: 17"x7"
Tires: 225/45/17
Works for me.
Old Oct 17, 2006 | 04:47 PM
SlowCG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">looks good, and you dont have any trouble with your turning radius? also where did you order those from? and how much were they&gt;</TD></TR></TABLE>
No problem with the turning radius, i orderd from victoriatire.com (might have an S on the end of tire im not sure) and they cost 1000 dollars even with tires. They are Knock off 5-Zigens. But i have not had any problems with them, they are great and service was good as well no problems with shipping or anything. That site is located out in cali and they have been around FOREVER! So there a good buissness and have some of the best prices.
Old Oct 17, 2006 | 04:50 PM
SlowCG's Avatar
and here are some more pics just to give u different angles. I know i need a drop its coming lol, but it some lights the wheels look a little like chrome but the finish is silver.
Old Oct 17, 2006 | 06:09 PM
skingfreak's Avatar
thankyou! this is very helpfull, i think 18's give me the look i want, since i wont do a drop (too much snow in the winter, i need as much clearance as possible ) i might actuley go with those. I guess we will see how the money looks come spring. Thanks a ton!
Old Oct 17, 2006 | 06:10 PM
skingfreak's Avatar
and 40 is your offset? im a real noob when it comes to wheels. did you need any spacers?
Old Oct 18, 2006 | 11:28 AM
SlowCG's Avatar
Nope no spacers, and no problem on helping out, i know how annoying it is to look for wheels for awhile.
aznsupastar
Mar 11, 2009 07:42 AM
skingfreak
Apr 15, 2007 01:45 PM
SJTrance
Apr 21, 2004 05:49 PM
EL-Driver
Apr 11, 2003 05:59 AM
