Engine is having breathing problems. Oil in PCV valve/hose and some blow by
Old Oct 13, 2006 | 07:28 AM
SkoundrelUSA's Avatar
cute little bastard
Default Engine is having breathing problems. Oil in PCV valve/hose and some blow by
Ok so I just put together my gsr block/B16 head setup and I'm having a decent amount of blow-by . Oil is all around my oil cap, and I see the headgasket leaks a little oil also. So I checked my PCV valve/line and there was oil in it. I think that might be why I'm smoking a little blue sometimes also...
Not sure what I should do. I have a normal black box/PCV valve setup and just the hose from the valve cover to the intake pipe. Am I missing anything else, breathing wise? Not sure whats going on here. Should I look into getting a catch can or something?
I also just put on a new PCV valve (2 days old) and it still has the same symptoms
Old Oct 15, 2006 | 02:29 PM
cute little bastard
Default Re: Engine is having breathing problems. Oil in PCV valve/hose and some blow by (SkoundrelUSA)
datoad
Oct 5, 2017 08:31 AM
jdmfoglights
Jan 8, 2014 09:50 PM
Set O' Nines
Oct 30, 2012 07:49 PM
SkoundrelUSA
15
Oct 31, 2006 06:27 PM
GruvyTune
Oct 22, 2001 01:29 PM
