Need Help....Car Dead
Old Oct 13, 2006 | 12:40 AM
xionl1350's Avatar
Default Need Help....Car Dead
I'm kind of new to the car scene so I need some help here. My gf's 89 civic dx hb died and I can't figure what the hell is wrong with it. I checked the starter, alternator, spark plugs, batteries, and all the belts but they are all fine and still work. Is there anything else I should be looking for?
Old Oct 13, 2006 | 12:44 AM
SiMateoAko's Avatar
Default Re: Need Help....Car Dead (xionl1350)
fuel pump?
Old Oct 13, 2006 | 12:59 AM
xionl1350's Avatar
Default Re: Need Help....Car Dead (SiMateoAko)
Okay I'll check that next, but if it isn't that than is there anything else that it could be?
Old Oct 13, 2006 | 11:30 AM
Perfectionist's Avatar
Could be a number of things.
Timing belt broke. (look through oil filler cap hole for cam turning while cranking, or pull off the distributor cap and look for rotor turning)
Ignitor/ignition module died. (look for spark while cranking)
Main relay failed. (listen for fuel pump priming for 2 seconds when the key is first turned to 'run' position)
Ignition switch (kind of self explanitory)
Out of gas?
Ef4doorwagon
16
Nov 19, 2015 03:37 PM
smoore117
Honda CR-V & Element
22
Nov 10, 2014 05:54 AM
graycivic
Mar 2, 2013 08:15 AM
ek-g6
Oct 9, 2007 01:29 PM
bullwinkle777
Jul 21, 2007 06:18 PM
