Mount mount w/ PICS
Old Oct 13, 2006 | 12:17 AM
SupaMien's Avatar
Default Mount mount w/ PICS
I have a 98 civic Ex w/ a b18c in it. Unfortunately the shop that help me pull out my engine did something and now my engine rocks back and forth pretty bad. Question is, is there a bolt that goes through the motor mount on the driver side? See pictures for details
Here is the driver side motor mount for location reference. Now look below
Old Oct 13, 2006 | 03:37 AM
JSPECSIR's Avatar
Default Re: Mount mount w/ PICS (SupaMien)
theirs a different older p/s bracket that wraps around and bolts their. its normal for it to be empty.
Old Oct 13, 2006 | 04:05 AM
4DeepCivic's Avatar
Do you have all your motor mounts bolted up? all five? You're probably using your stock mounts, which are soft. Buy after market ones, I bought the whole Mugen engine mount set. That should cure your engine rocking problem.
Old Oct 13, 2006 | 04:22 AM
myEK=slow's Avatar
yeah, that mount is made for a d-series. after my b16 swap, i replaced it with another stock mount and it already is wearing pretty bad. Save up and get the hassport kit. All that mount is, is a little piece of rubber and a metal rod that doesnt connect anywhere, just sits in a pivot cup.
Old Oct 13, 2006 | 05:20 AM
mike1114's Avatar
Default Re: (myEK=slow)
look under the gold bolt to the right on top of the tripod mount. Top picture.
Is the rubber inside the tripod all fuked up? This mount is notorious for breaking. I broke one totally with just an ACT clutch, everything else OEM with a D series motor.
B00M3R
Feb 17, 2010 02:02 AM
LiL accORd RideR
Jan 21, 2005 03:15 PM
TurboTagTeam
11
Dec 24, 2004 12:00 PM
Loveless
Oct 14, 2003 09:52 AM
Vtecivic99
Sep 20, 2002 05:08 PM
