D16Z6- Anyone use Skunk2Cams an Diff ECU?
Ay D16Z6 using:
"Stage I: Stage I profiles are designed to offer the widest possible powerband and be compatible with factory valvetrain components. These camshafts are designed to retain stock idle and are currently CARB EO-pending. Upgrading to Skunk2 Racing valve springs is recommended. Stage I profiles are relatively easy to tune for maximum power output"
Ay inputs or dyno charts?
and Skunk2 ECU:"This is the ultimate racing ECU program for naturally aspirated VTEC engines. This program significantly widens the powerband making peak torque sooner and longer. Fuel and timing parameters are altered. Skunk2 Racing ECU's are used exclusively in both our drag racing and road racing cars. Can be used with SOHC and DOHC engines. ECU core is required for reprogramming"
OR
Does Hondata have anything for N/A cars?
Thanks!
OR
Thanks!
Jspec_Imports
Jun 9, 2009 01:56 AM
