Short shifter install.
any of yunz guys know how to go about removing the boot of a 95 accord so i can access the shifter and put my short shifter on? pics, words? all help is appreciated. thanks a bunch
1. Lift up center glove box, pop off the plastic piece with flat head remove 2 screws.
2. Pull out the cup holder, remove 2 screws under there. Then you should be able to lift up the entire piece
http://ledautomotive.com/HowTo...t.jpg
http://ledautomotive.com/HowTo...s.JPG
http://ledautomotive.com/HowTo...s.jpg
http://ledautomotive.com/HowTo...l.JPG
Hope that helps..
Hope that helps..
ok. i apparently had a slight mis-naming issue. its a short-throw shifter or a short-shift adapter. its just as piece of billet aluminum. you can see a pic. at the bottom of this page > http://www.secureleadercom.com...block . i don't know where to put it on. all help is appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordSleeperZzZ »</TD></TR><TR><TD CLASS="quote">ok. i apparently had a slight mis-naming issue. its a short-throw shifter or a short-shift adapter. its just as piece of billet aluminum. </TD></TR></TABLE>
Eeeek... Bad experiences with the adaptor here. I used a DC Sports adaptor, and didn't realize how bad it was until I finally removed it. A short throw shifter like PSpec's is absolutely amazing. I can't begin to describe how great the short shifter is, vs an adaptor. Sorry for going off topic.
http://pspectuning.com/images/...0.jpg
In this picture, you can see where the top shift rod connects to the shifter. The adaptor should somehow fit on to this projection on the stock shifter.
DC5mike
Sep 30, 2007 11:53 AM
eagleclawracing
May 1, 2006 03:46 PM
lif3tak3n
Dec 2, 2005 08:16 AM
