Ground
Old Oct 12, 2006 | 05:55 PM
Felliph3's Avatar
Default Ground
What is ground wire and grounding and that stuff?what does it do?thanks,got pics?
Old Oct 12, 2006 | 06:00 PM
Miracle's Avatar
Default Re: Ground (Felliph3)
A ground wire is part of an electrical circut. Without it, you cannot complete the circut, and you get no power to your accessories, or whatever is electrical.
An atypical ground wire:
There are 3 main components to a simple electrical system: Power, ground, and load. Everything electrical has to have those 3 things.
Any questions?
Old Oct 12, 2006 | 06:32 PM
ricekiller1's Avatar
Default Re: Ground (.Red.EM2)
well put
Old Oct 12, 2006 | 06:58 PM
Felliph3's Avatar
Default Re: Ground (ricekiller1)
then were the hell does this lead to and what does it do especifically?The bronze wire on the right hand corner below,attached to the valve cover witha a screw,some cars i see have them disconnected for some reason
Old Oct 12, 2006 | 06:59 PM
Miracle's Avatar
That ground coming from the motor on the lower right side grounds usually to the radiator core support.
It grounds the engine to the chassis, which completes the gigantic circut that is your motor.
Old Oct 12, 2006 | 07:01 PM
Felliph3's Avatar
are the double hoses with a blue cap in the front a/c?i get the feeling it is,what does which one do?Recently im focusing on learning as much as i can on the B engines,hate to be an *** asking too much but i appreciate it
Old Oct 12, 2006 | 07:04 PM
Miracle's Avatar
Uh, if you want a/c you need those lines.
Those are refrigerant lines. They carry R134A refrigerant to and from the compressor in your car. It is ALOT more complicated than that, one carries a high pressure gas, and the other carries a low pressure liquid, but both come from the same element inside the A/C system, the r134a freon. I won't get into that here, but that is why they are there.
You remove those, you will not have A/C.
psycho.chicken
Jul 14, 2006 06:52 PM
SunkistRex
Mar 15, 2004 01:12 PM
garyyam
Oct 22, 2002 04:05 PM
