RPM Limit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">by upgraded valvetrain you mean type-r valve cover right?</TD></TR></TABLE>
LMAO
LMAO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White V6 »</TD></TR><TR><TD CLASS="quote">Dose any one know how to remove the rpm limiter
Thanks
Dont do it. By asking, we know right off the bat you dont have a built motor to handle these rev's, because you would know how to remove the limiter. You would also know your power drops off severly after redline on a stock motor.
Thanks
</TD></TR></TABLE>Dont do it. By asking, we know right off the bat you dont have a built motor to handle these rev's, because you would know how to remove the limiter. You would also know your power drops off severly after redline on a stock motor.
Thanks </TD></TR></TABLE>
Seriously...
1. It's not a simple process
2. Your motor will not like you for it, and not be able to handle it.
3. There is absolutely no positive effects, ESPECIALLY on the J30.
Seriously...
Not a good idea on the V6 IMHO as redline is set at a point where valve float will not occur. If you go above that you have a good chance of floating your valves and smaking one on a piston.....
