SiR cluster swap VSS wiring, need confirmation...please
OK well I just picked up a SiR cluster and a 99 Civic Si Elec VSS, the only hting I am missing is the plug/pig tail for the VSS...so I am just going to use some clips but I need to confirm which wire goes where...this is what I have established so far...
G S P
Blk|Yel/Blue|Yel/Wht
G=Ground S= Signal P=12v Power
Then those are the wire colors I believe are on the connector
Say that is the looking down at the speedo/ VSS... here is a connector I referenced it to compared to the info I had found...anyone confirm this?
http://s2.supload.com/image.php?get=DSCN3927.JPG
G S P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16civster »</TD></TR><TR><TD CLASS="quote">do you see the RED search in the corner of your screen use it its faster
Hey noob Go FU@K yourself did you even read my post you dumb FU@K...
I search for an hour and came up with the wire colors and what they do and based that off of a picture I found of the plug, which i don't have, I just need a comformation of which wire goes to which post on the vss...
</TD></TR></TABLE>Hey noob Go FU@K yourself did you even read my post you dumb FU@K...
Didn't want to chance sending power to something that isn't supposed to get it...also I know people have done this before so all I need someone to do is look at there Elec VSS...
Between H-T and google I could find 1 place that said or showed what I am asking so I combined a few sources to come up with my assumption just need someone to confirm this...seems like an intelegent questions, not like how do I check a CEL
the outers are power and ground, the middle pin is your signal output.
just use a little fuse (like 5amp) on the power side, itll blow before anything bad happens to the VSS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">the outers are power and ground, the middle pin is your signal output.
just use a little fuse (like 5amp) on the power side, itll blow before anything bad happens to the VSS</TD></TR></TABLE>
Thanks, thats eactly what I was looking for
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">Hey noob Go FU@K yourself did you even read my post you dumb FU@K...
I search for an hour and came up with the wire colors and what they do and based that off of a picture I found of the plug, which i don't have, I just need a comformation of which wire goes to which post on the vss...</TD></TR></TABLE>
found this in 1 sec im not a noob ive been on here for 10 years so just relax...the reason why i said to search is because that is how i did my electronic vss
https://honda-tech.com/zerothread?id=1536136
Honda-Tech.com: vss plug wiring
Honda-Tech.com: vss plug wiring</TD></TR></TABLE>
If you read my post you would see I linked that picture...also notice how that dude wanted the same info and never got the answer either
I used that info based on other stuff I found and just wanted someone to confirm it, thanks for your helpful comment you need to read more...
4LugR
Jan 22, 2011 07:02 PM
Power Rev Racing
Sep 12, 2004 06:58 PM
