Sanding/Primering hood...
Old Oct 12, 2006 | 04:32 PM
Tuesdaynightfever's Avatar
Default Sanding/Primering hood...
Well I'm prepping my girl's hood before taking it in for paint. I had a few questions. I first planned on stripping the majority of the paint with Aircraft Paint Remover, then sanding it with some wet/dry sandpaper. Then I was going to simply primer it and be done with it. I was just wondering what type of primer you guys would recommend for a hood. I didn't know if I needed hi-temp or anything due to the hood getting slightly warmer than most body panels while the car is running. Any help would be greatly appreciated as this is my first time prepping anything for paint. Thanks in advance
Old Oct 12, 2006 | 05:26 PM
TTT!
Old Oct 12, 2006 | 07:33 PM
4drSi's Avatar
Default Re: Sanding/Primering hood... (Tuesdaynightfever)
if you find out what to use lmk, im doing my fenders. thx
Old Oct 12, 2006 | 07:38 PM
ErMaK's Avatar
Default Re: Sanding/Primering hood... (4drSi)
I would recommend a high-build epoxi primer. It tends to fill up any low-spots that you may have and any minor scratches that you might get when sanding. I've used it before and it turned out pretty good...Here is pic. Its not really the best, but kida gives you an idea...It sort of lays down "thicker" than most other primers. I like it.
Old Oct 12, 2006 | 09:03 PM
Thanks for the info man. You got PM
Old Oct 12, 2006 | 09:46 PM
Bump for more suggestions
Old Oct 12, 2006 | 10:39 PM
Before bed bump!
Old Oct 13, 2006 | 07:58 AM
Default Re: (Tuesdaynightfever)
TTT!
Old Oct 13, 2006 | 02:30 PM
Bump for some more suggestions on what kind of primer to use
Old Oct 13, 2006 | 04:00 PM
mike9571's Avatar
If your spraying over bare metal you need to use some type of self etching primer. Then ontop of that (no sanding needed) you can just spray some high build like the other guy stated. There is no need to use high temp paint. .
The_Head
Paint and Body
Sep 23, 2009 07:30 AM
BB1LOViN
Paint and Body
12
Dec 25, 2007 04:19 PM
Si_chRis
Paint and Body
Oct 30, 2007 09:22 AM
TurboEg
Jul 26, 2003 05:12 PM
