FS: Sleeved 84mm ls block, arias pistons, eagle rods
like the title says:
sleeved 84mm ls block from RS machine. This block will take huge amounts of boost of a very heavy shot of nitrous. i was planning on running this motor on a 200 shot in my hatch but things have come up so i must sell it. with a set of custom pistons this set up can hold up to a 400 shot with proper tuning.
I also have a set of Arias pistons with arias high tension rings. the piston are an 11.5 compression ratio.
The rods are Eagle "H" beams that have been machined by RS to accept the larger GSR bearings so no worries about the crappy LS ones. If the buyer is worried about getting the right rod bearings, i can provide them.
I can also throw in a mostly complete ls motor that can be used for the crank or a spare block or whatever. heres the link to pics, let me know if you want a picture of anything in particular. $1900 obo http://s104.photobucket.com/albums/m191/xhellvisx/ .......thanks
Acura_I-RS
Apr 24, 2005 06:27 AM
TurboB18C1
Sep 18, 2004 03:17 PM
tegasaurus
Jun 10, 2004 01:49 PM
