Cooling Question?
Old Oct 12, 2006 | 03:38 PM
sohcvtec91hatch's Avatar
Default Cooling Question?
Okay I've been having all sorts of problems with my car not revving past 6500rmp.
and now today it was running great all over town, untill I got stuck in some traffic at a light and it warmed up a little more then it wouldn't go past 6500rpm again. It also does it when the temp is real cold. It doesn't go more than 1/2 way up on the temp gauge ever. Any thoughts on this would help out so much.
Old Oct 12, 2006 | 05:39 PM
Default Re: Cooling Question? (sohcvtec91hatch)
Any help would be much appricieated!
Old Oct 15, 2006 | 03:36 PM
C'mon I know someone around here can help me.
Old Oct 15, 2006 | 03:41 PM
89 civic si's Avatar
i would check the wiring at the distributor..i would also check the timing...did you have the maps for the d15b vtec, do you run a 4 wire or a 1 wire o2 sensor?
Old Oct 18, 2006 | 04:22 PM
Default Re: Cooling Question? (89 civic si)
Why the wireing at the Distributor? And I have a 4 wire o2 sensor because of the boomslang conversion harness. The ecu I have was chipped by Kenji for the D15b
jlhobdey
18
Jan 21, 2020 03:08 PM
sohc_ef2
Sep 29, 2012 05:34 PM
video_voide
Feb 25, 2012 10:49 PM
TylerH
Apr 7, 2006 02:18 PM
wrEcKed_LX
May 16, 2005 07:20 PM
