92 accord distributor problem
Old Oct 12, 2006 | 02:07 PM
gmrnguyen's Avatar
Default 92 accord distributor problem
hey guys i have a little problem with a replacement distributor i bought the other day. But when i went n try installing it, i noticed that the one on my 92 accord has a 5th plug and the new one i bought doesn't. will it be a problem is i didn't plug the 5th one in? or is it for the wrong model?. Thanks
p.s. the pic below is the new distributor i bought.
Old Oct 12, 2006 | 03:24 PM
standbackimapro's Avatar
Thats the wrong Distributor for that car
The 92 Has A External Coil (thats where the 5th wire went)
After like 1991, The internal Coil distributors were having a heat problem, So they switched to an external Coil
That distributor is for a earlier year
Your car wont run with it
Old Oct 12, 2006 | 03:34 PM
hondadude's Avatar
Default Re: 92 accord distributor problem (gmrnguyen)
The actual housing should be the same, and the caps should interchange.
You'll need to open the new one and remove the coil, and reconfigure the wires.
It can be made to work, but you could always just go back to the salvage yard and explain the difference to them.
shadetree101
Feb 15, 2012 11:46 AM
B16Turtle
May 28, 2009 01:03 PM
dlmar
Classic Hondas
Jun 7, 2008 08:17 PM
floridatreasure9
Jan 10, 2006 12:42 PM
