code 1324 knock voltage
I just installed a new motor in a 2002 civic ex. The old motor sucked up water in the intake. I took it to advance auto and had the code cleared but the 1324 is staying. I used most of the old stuff. The car runs but is alittle ruff.
P1324 Knock Sensor Power Source Circuit Low Voltage
The knock sensor could be bad on the new motor, just replace it and it will go away.
EDIT: Did you transfer the sensor from your mototr, or did it come with one?
not sure where it is located on the 02.....I know its on the back under the manifold on the older ones. If I knew which sensor it was then I would be able to tell you if it was the new one or the old one.
Maindrian
Jun 29, 2006 01:45 PM
