Suspension & Brakes Theory, alignment, spring rates....
Upper a arm noise???
Old Oct 12, 2006 | 01:37 PM
Racermech's Avatar
Default Upper a arm noise???
I asked in the integra forum and got virtually no help.
I installed omni upper a arms about 75mi ago, Just that last few days a creak has developed. I can push down on the fender with very little weight and hear it. When driving I dont hear it, untill I slow down and hit smaller bumps.
I am guessing it is the factory bushings. Do I need to lube them, tighten the bolts a bit more, loosen the bolts a little, remove the paint??
Old Oct 12, 2006 | 01:44 PM
TunerN00b's Avatar
Default Re: Upper a arm noise??? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">I asked in the integra forum and got virtually no help.
I am guessing it is the factory bushings. Do I need to lube them, tighten the bolts a bit more, loosen the bolts a little, remove the paint??</TD></TR></TABLE>
Does Omni use polyurethane bushings? If so, those will creak if not kept adequately lubricated. My Ingalls poly bushes drove me crazy with noise.
Old Oct 12, 2006 | 02:24 PM
Racermech's Avatar
Default Re: Upper a arm noise??? (TunerN00b)
You have the black (or in my case red), A Arm, then you have the two other pieces the you bolt down to the arm and to the body. I think the bushing that goes into the arm is making the noise. I have no reason to believe it is the ball joint as it only have about 75mi on it and I checked to make sure there was greas on the ball and there was.
Old Oct 13, 2006 | 07:45 AM
Racermech's Avatar
So this morning I too the olf trusty WD-40 and sprayed it all over the rubber bushing thing, and the creak stopped 100%.
Guess I will pull it out this weekend and lube the hell out of everything. I mught even stick a plastic washer in there so it is not rubber on paint contact.
Old Oct 13, 2006 | 08:32 AM
hayabusa160's Avatar
you kinda need to have those bolts loose then tighten the bolts with the suspension loaded so take the wheel off and jack it up then tighten the bolts to those bushings.
then its not always preloaded and sqeaking.
thats what i did when i had the same problem on my lca
Old Oct 13, 2006 | 09:09 AM
Racermech's Avatar
Default Re: Upper a arm noise??? (hayabusa160)
I noticed the stock ones where not preloaded, so I tired to copy that, Guess i got the left side correct, but not the right.
Thanks for the input!
Old Oct 13, 2006 | 03:59 PM
one bad dx's Avatar
I have the same problem with my ingalls kit. I was told it may be the bump stops but I'm gonna get a better look tomorrow while it's on the lift. Funny how a majority of us have the same/similar problems with suspension.
BuickMike
Jan 10, 2011 09:49 PM
PatrickGSR94
Suspension & Brakes
Mar 10, 2008 07:14 PM
Built B16A
May 26, 2006 11:58 AM
Blazin Civic
11
Jun 20, 2005 03:15 PM
