Poormans Type R track time
swap was just completed 99 coupe gsr block b16 head...(intake header exhaust) anyone with same or similar set up know what kind of times i shoud be looking at when i hit the 1/4 mile??
i would first try and get that 60ft down to at least a 2.3 if your on street tires. 2.8 is pretty high. did you have a lot of wheel hop or bog of the line? i would also guess that you should be trapping somewhere around 92-94 mph. go to the track and keep practicing. second time i went to the track i took off 1.3 seconds from the first time. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustdgst »</TD></TR><TR><TD CLASS="quote">any ideas??</TD></TR></TABLE>
you're either spinning the tires like an *** or bogging like crazy.
practice makes perfect.
