gsr swap pass emissions??
Old Oct 12, 2006 | 05:41 AM
civic99gsr's Avatar
Default gsr swap pass emissions??
99ex with gsr swap... will it pass emissions?? any helpful hints on how it can??
Old Oct 12, 2006 | 07:54 AM
fmrprojects's Avatar
Default Re: gsr swap pass emissions?? (civic99gsr)
just hook up all the smog emeissions that the gsr came with, dont have any codes, get a motor that is your car year or newer. do a tune up and take it to pass emissions at the referee. in cali thats what we have to do
Old Oct 12, 2006 | 09:24 AM
TurboTagTeam's Avatar
Default Re: gsr swap pass emissions?? (fmrprojects)
Your in TN??? I dont think you have smog. You probably just have to pass emmisions. As long as the engine is running properly you should be fine.
Old Oct 12, 2006 | 09:52 AM
civic99gsr's Avatar
Default Re: gsr swap pass emissions?? (TurboTagTeam)
I am in TN... they hook up to my computer and the ecu has been changed... will that affect it any?? will the o2 sensors off of a factory civic work on the cat??
Old Oct 12, 2006 | 10:02 AM
Relic1's Avatar
you will need an OBD2b P72 for your 99 civic.
as long as the CEL is off and you've driven the car for a little while you will be fine.
Thankfully an OBD2 ECU is all you need in pretty much any state other than cali.
Old Oct 12, 2006 | 10:15 AM
civic99gsr's Avatar
Default Re: (Relic1)
I do have the p72 ecu hooked up... anybody have a gsr cat and good o2 sensors for sale?? how about ideas on what is the best cat to buy with the dual o2 sensors?? direct fit or weld on universal??
Old Oct 12, 2006 | 10:21 AM
jadugartir's Avatar
Default Re: (civic99gsr)
any cat should work... i got a b series and a cat off a civic cx, its the same size piping.
Old Oct 12, 2006 | 10:32 AM
civic99gsr's Avatar
Default Re: (jadugartir)
anybody got the Magnaflow universal with dual sensor mounts?? anybody used this one to pass emissions?? anybody have the sensors for the 98 gsr motor??
Old Oct 12, 2006 | 10:44 AM
civic99gsr's Avatar
will civic o2 sensors fit on my gsr cat??
Old Oct 12, 2006 | 11:57 AM
Relic1's Avatar
I did not say this.... (slightly against the law)
install an O2 simulator for the secondary O2
run no cat
get no codes and pass emissions.
total cost ~$50 and you will never have to worry about your O2 or cat going bad.
BlackSage
Apr 2, 2013 09:50 AM
lynzysi
Aug 13, 2008 08:20 PM
NsX_CrX
Jul 16, 2007 07:28 PM
EK4door
20
Feb 29, 2004 03:21 PM
APEX CRX
Jan 21, 2004 03:13 PM
