B16 sir1 parts interchange guide?????
hey all i've red through the archives and searched all over the internet but can't seem to find a complete list of parts that interchange from usdm b16's to jdm b16 sir 1's.. basicly i'm wondering about front and rear main seals and the rest of the gaskets that can be replaced... is there a kit like the 92-93 complete gasket kit that will work w/ the sir 1???? i've only been able to find parts interchange for the following:
plugs bkr6e-n11
wires 92 gsr
distcap and rotor 90 gs
clutch 90 gs
throttlecable 90-91 gs
t belt 94 del sol vtec
water pump 94 delsol vtec
upper rad hoses 92-93 gsr trim
lower rad hoses 90-91 gs trim
alt belt. 90 gs
any more parts that are interchangable that can be added to this list is greatly appreciated. i am not including axles or prefab linkages... this is a OEM rebuild list.
but i'd still like to know about them so e-mail me. i'll probably put up a page w/ complete swap info plus pics step by step.
ohh this sir 1 swap is for 88-91 ef si/hf
[Modified by Nismo240sx1, 2:40 PM 5/3/2002]
plugs bkr6e-n11
wires 92 gsr
clutch 90 gs
alt belt. 90 gs
Here is a list that might help:
Gaskets Head gasket = US '94+ DelSol VTEC
Valve cover gasket = US '94+ DelSol VTEC
Spark plug O-ring gaskets = US '94+ DelSol VTEC
Intake manifold gasket = US '94+ DelSol VTEC
Exhaust manifold gasket = US '90-7 Integra or US '94+ DelSol VTEC
Spark Plugs = Any US B series motor
Cap and Rotor = US '90 Integra
Spark Plug Wires = Any US B series
Thermostat = US '90-1 Integra, US '94+ DelSol VTEC, '99+ Civic Si
Timing Belt = US '94+ DelSol VTEC
Water Pump = US '94+ DelSol VTEC
Lower Radiator Hose = '91 Integra
Upper Radiator Hose = Universal, may need trimming
Alternator = '90 Integra
Oil Pan = Any US B series
Oil Pump = 94 DelSol VTEC
Crank Pulley = Any US B series
Clutch = US '92 Integra GSR
Pressure Plate = US '92 Integra GSR
Pilot Bearing = Any US Civic/Integra
Throw-out Bearing = US '91-2 Integra, P/N 22810-ps1-015 $47.05
Flywheel = Any US B series
Axles = http://www.raxles.com, can use others, but best solution.
Intermediate Shaft = US '94+ DelSol VTEC
Mounts = http://www.hasport.com
Shift Linkages = http://www.hasport.com
Headers = best to use JDM B16
As for the front and rear main seals my guess would be the ones from the 94+ del sol Vtec due to the fact that most of the other gaskets interchange from that motor.
Some others...
Clutch 90-91 integra also
Throttle Body gasket - 90-91 integra
90-93 intermediate shaft
90-93 modified integra axles see http://www.hasport.com
I thought thermostat and connecting pipe O rings had to be 90-1 integra unless same part # as del sol?
hth,
Monty
hth,
Monty
ludedude94
Oct 25, 2004 02:25 PM
