97 Gsr wont pass CA smog
I hate smog. I failed it! 97 gsr obd2 tired to look for cat online to replace myself. Plenty problem is says fits all integras except CA MODELS..Uhhhh...wtf i just wanna get a cat at a decent place to replace and pass smog.
Anyone can help me out id appreciate it.
Measure ur pipe diameter.
Order a magnaflow cat for ~$60 shipped.
Take it to the muffler shop & tell them to replace your cat (labor at about $50).
Enjoy your passed smog test.
Its that simple!
* Ca has some BS standards on ObdII cats. I think they need to be "3 way cats" which are better at doing their job.. Nehow, if you just buy a magnaflow cat that says 3way or ObdII compliant then just buy it. DISREGARD the CA bullshit
Signed,
Person that has passed many many smog checks & guy that has 2 extra magnaflow cats in his storage left over from past car purchases that didnt pass smog.
Its that simple!
Signed,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowPhoenix095 »</TD></TR><TR><TD CLASS="quote">Any muffler shop should have a cat for your car.</TD></TR></TABLE>
Ok ill go look on ebay. Found one for 63.78 shipped not too bad. I gotta find a place to install it. Ive been getting extensions since the summer im tired of looking at that thing .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones »</TD></TR><TR><TD CLASS="quote">Try Sea foam....</TD></TR></TABLE>
Best bet...
Best bet...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">or u can look for a guy to past you illegally? but its going to cost you.</TD></TR></TABLE>
Or he could fix the problem and not be a gross polluter.
He'd probably save some money, as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">or u can look for a guy to past you illegally?</TD></TR></TABLE>
How to: <FONT COLOR="red"> LEGALLY SMOG ANY ENGINE SWAP:</FONT>
The best way to <FONT COLOR="red">SMOG</FONT> your ride is the legal way! We legally pass the vehicles using CNG/LPG/propane gas. The vehicles are slightly modified and passed on propane, and then, upon the owners discretion, changed back to regular pump gasoline, there are no permanent modifications done to the vehicle, the turnaround is about 4-6 hours.
We will gladly explain the conversion process to anyone who would like to convert their own vehicles, please feel free to email us at: jargon_@hotmail.com with any questions. Any engine can be legally smogged and registered. Turboed, supercharged, high compression race motors, <FONT COLOR="red">K20's, B20's, H22's</FONT>, any engine in any car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wardseg6 »</TD></TR><TR><TD CLASS="quote">ok heres the results of the smog
HC max 61/45 tested 64/52
CO max .54/.53 tested .21/.27
what do you think? the cat? or something else looks like it barely passed..</TD></TR></TABLE>
You are barely failing. Retard your ignition timing to 14 degrees BTDC and heat up the cat a little more before you go test again. That should be enough to pass. Ask for a pretest before you actually do the smog test next time too.
what are you at on o2?
you are either running slightly rich or slightly lean indicated by the HC content
if you were also high on o2 then that will indicate that the car is running slightly lean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harrykong »</TD></TR><TR><TD CLASS="quote">move to another state...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR »</TD></TR><TR><TD CLASS="quote">Just do a fake smog check it always works. </TD></TR></TABLE>
We are in 2006, smog techs nowadays are known to take your money and still snitch you out. Only work with people you know and trust.
Looks about right. When my 00 GSR passed, it was by 1 ppm HC on both speeds.
Honestly, the cheapest way to pass is to just go get a bottle of GTP and follow the directions. You're only off a little, and it should be able to get you back under the limit.
Also, make certain that you get your catalytic really hot before the test. Take some time on the freeway, in 4th, and keep the revs up a little, and get that exhaust smoking hot. Then, make sure they don't let you car just sit in the parking lot cooling down, idle it in the parking lot if they aren't going to do the test when you get there.
