brake troubles
Old Oct 11, 2006 | 10:02 PM
stwano's Avatar
Default brake troubles
I got an 88 crx dx and my brakes are stopping the car when im not using the brakes. I take 25 min drive home from work and rotors are glowing. need a fix ASAP
I changed the calipers and got a new master cylinder and blead the whole system and still cant figure this out? Any ideas???
Old Oct 12, 2006 | 01:04 PM
stwano's Avatar
Default Re: brake troubles (caliscrilla)
any suggestions?
Old Oct 13, 2006 | 11:50 PM
stwano's Avatar
Old Oct 14, 2006 | 12:58 AM
pepper's Avatar
cool get a video, i wanna see it glow..but i have no idea, it seem like theres too much pressure... does it drags your car alot? like your using more throttle then you should be?
Old Oct 14, 2006 | 09:58 AM
thesmogman's Avatar
Check your brakelines for kinks. Is it on one side or both?
Also check the oneway valve that goes to the brake booster. The arrow should point toward the engine.
Did you apply the hi temp grease to the caliper pins?
That is all for now
Old Oct 14, 2006 | 10:10 AM
JKGONZALEZ3's Avatar
Default Re: (pepper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pepper &raquo;</TD></TR><TR><TD CLASS="quote">cool get a video, i wanna see it glow..</TD></TR></TABLE>
Old Oct 14, 2006 | 10:11 AM
daveb91's Avatar
When you had the wheels off and bled the brakes did you notice the dragging then?
Old Oct 15, 2006 | 07:38 PM
stwano's Avatar
Default Re: brake troubles (thesmogman)
the brakes started locking up before i did anything with the brakes. they start locking up after about 15 mins of driving.(15 mins is time period i get off the freeway). i did use grease. and my brakelines dont have any serious looking damage or kinks. but they do look worn out. ill try changing those out and see what happens.
Old Oct 16, 2006 | 11:00 AM
1 Fly SI's Avatar
Did you grease the pins on the caliper bracket that the caliper bolts to?
Old Oct 16, 2006 | 11:20 AM
Max Kling's Avatar
Could be booster not letting pressure out. I bought an auto zone booster and it did the same thing, so I returned it and bought an oem one for 300$ and hasnt failed me since.
Old Nov 4, 2006 | 12:17 AM
stwano's Avatar
ok...I replaced calipers, proportioning valve, brake booster, one way valve, and baught a new master cylinder, and my front brakes are still locking up. I would be going down a hill in nuetral, and the car will slow to a stop.
I capped one end of the one way valve, so the hose frome the booster to the one way valve is open. This way id have to stop by using all muscle. Then i would go down a hill and it will roll down a hill like its suppose to.
Now im thinking i baught a faulty master cylinder or faulty brake booster. Or installed something wrong.
Is there any certain proceedure when installing a master cylinder or brake booster??? I cant figure this out
Old Nov 4, 2006 | 07:43 AM
stwano's Avatar
Old Nov 4, 2006 | 07:54 AM
ic's Avatar
ic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caliscrilla &raquo;</TD></TR><TR><TD CLASS="quote">ok...I replaced calipers, proportioning valve, brake booster, one way valve, and baught a new master cylinder, and my front brakes are still locking up.</TD></TR></TABLE>
Did you replace the brake lines too?
Is this happening to just one wheel or what?
Old brake lines can crack internally and the rubber can flake off inside causing a one way check valve that can cause the caliper to lock up.
When your brakes are locked up, try cracking the bleeder screw on the faulty caliper. If it squirts good (with no brake pedal input) then the system likely has a clog that is holding pressure at the caliper all of the time.
does that make sense?
Old Nov 4, 2006 | 12:30 PM
KURUPTinc's Avatar
Default Re: brake troubles (ic)
Are you sure its the fronts locking and not the rears? Just a question cause i know its happend before. But if its the front it does sound like its the master cylinder did you notice anything abnormal when you took off the cylinder was the rod bent from the brake pedal?
Old Nov 4, 2006 | 07:35 PM
stwano's Avatar
the brakelines are the only thing i did not replace yet.
ic, thanks for the info. i just ordered a set or ss brakelines.
KURUPTinc, i didnt notice any damage or anything wrong with the old mc
chris3k
Nov 2, 2008 08:05 PM
seeareex
Mar 3, 2008 01:06 PM
gophat
Jan 7, 2007 05:32 PM
88_T-Rex
Jan 4, 2006 01:03 PM
zccrx
Sep 9, 2005 07:53 AM
