knock sensor??
looking at doing a z6 swap into a 92 DX hatch.... am i correct in assuming that there are only 2 wires that need be lengthened from the plug under the hood. the Vtec pressure switch and the Vtec solenoid. the only time you need to worry about a knock sensor is in a B series swap correct?
cliffs notes
does a d16z6 use a knock sensor?
cliffs notes
