ECU Question
Old Oct 11, 2006 | 07:56 PM
gilligan354's Avatar
Default ECU Question
I have a POJ-L52 automatic ecu. Will this work in a 96/97 JDM Honda Accord Wagon E-CF2 SiR with an automatic and a H22A engine?
Old Oct 12, 2006 | 01:06 AM
xamraci's Avatar
I would assume it might work...although your fuel tables are going to be all wacked out. Is the POJ a CIVIC sohc ecu, a DOHC ecu. Seems that its also an EDM ecu...niether of which I can confirm. The car will run on it even if the fuel tables are messed up...however your idle enrichement will be all screwy, you wont make very much power...amoung other things...I belive the OBD2 h22 came with 290cc injectors...not certain what the B16s came with...
Blake Harvey
Engine Management and Tuning
Nov 15, 2016 01:11 AM
importzero
Jun 23, 2010 08:26 PM
Entaka
Nov 9, 2004 09:00 PM
dominate9
Jun 8, 2003 04:49 PM
