whats needed for OBDI
Old May 3, 2002 | 10:00 AM
RC211V's Avatar
Default whats needed for OBDI
what ecu do i need for the odbI conversioon on a '00 GSR? i wanna do this because of the power i am going to make later in the life of my car. what ecu do i need and what wires, connectors, ect to modify?
thanks for your help plz
Old May 3, 2002 | 10:09 AM
maggsgsr's Avatar
Default Re: whats needed for OBDI (JDMintegGSR)
Just the proper wire harness and ECU,and your all set.
Old May 3, 2002 | 10:18 AM
gandhisan's Avatar
Default Re: whats needed for OBDI (maggsgsr)
I thought you needed a distrobuter? no?
Old May 3, 2002 | 10:25 AM
Quik Chris's Avatar
Default Re: whats needed for OBDI (gandhisan)
As of like 1/2 a year ago, I'm pretty sure that Skunk2 didn't make an OBD-2.2 conversion, in '98 they changed to 2.2, but (skunk2) may have released one since then.
The wiring harness (if availible) will allow you to use all your OBD-2.2 components with an OBD-I computer.
Old May 3, 2002 | 12:07 PM
RC211V's Avatar
Default Re: whats needed for OBDI (Midori Shinkansen)
when you say ecu can i just get a chipped ecu?
Old May 3, 2002 | 01:16 PM
JCushing's Avatar
cant chip obd2 ecu's. you need to use obd1.
upon re reading yes you can get a chipped ecu but usually you buy the ecu then get it chipped later. you can find sohc ecu's (p28) chipped for dohc with the mugen program alot for sale....
[Modified by JCushing, 5:18 PM 5/3/2002]
Old May 3, 2002 | 01:42 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: whats needed for OBDI (JCushing)
A few months ago I helped drop a 96 B18C1 engine into a 94 GS-R (car was being sold, the 94 engine was built and being put into another car). Anyway, all the ECU and wiring and everything was obviously OBD1. The only thing we had to do was use the 94 distributor and the 94 fuel injectors (different plugs on the harness). So if you get an OBD1 ECU and harness I would guess you would also need an OBD1 distributor and injectors.
2000DC2_freak
Jan 31, 2007 04:55 PM
neeks
Apr 20, 2005 03:45 PM
gser67
Dec 22, 2004 07:37 PM
iH8RICERZ
Oct 24, 2002 09:57 PM
kenji
Jan 28, 2002 06:41 PM
