car bogs out???????
Old Oct 11, 2006 | 06:11 PM
da6er's Avatar
Default car bogs out???????
when i 1st start my car and when im driving in low rmp's as i give it gas it bogs out but then picks back up. as if its not getting any fule? anyone know what it might be????
da6er's Avatar
Default Re: car bogs out??????? (da6er)
btw its a 93 integra ls vtec with a b16 head if any of that info will help thanx!!!
Old Oct 11, 2006 | 07:52 PM
TB123's Avatar
Do you have a fuel pump kill switch? I have one on my integra and it had bad electrical conections and it would start to run out of gas when I was accelerating. It would have no power for a second and then be perfectly normal a second later. Even if you don't have a kill switch, it could still be something wrong with your fuel pump. You could try checking the fuel pump wires under the back seat.
Old Oct 11, 2006 | 09:39 PM
BigD3154's Avatar
Default Re: car bogs out??????? (TB123)
Does it just feel really weak from say 1200rpm to 2500rpmishh? Or does it feel like its going to stall out at low rpm's?
Old Oct 11, 2006 | 11:26 PM
jdm_bones's Avatar
Check your injectors, they might be bad, also check your Fuel pressure....Fuel pump might be going out...
Old Oct 12, 2006 | 09:13 AM
siscoa36's Avatar
Default Re: car bogs out??????? (jdm_bones)
hey i have a ? i have a 99 ls auto and recently it has ben drivin like **** when i punch down the gas i move pretty fast but when i let off of it totally drags down and just started doing this, any ideas of what to do.
Old Oct 12, 2006 | 10:39 AM
da6er's Avatar
LIKES IT GOING TO stall OUT.. .. MY FULE PSI IS AT 75.. ..
Old Oct 12, 2006 | 02:02 PM
92DAIntegraXSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6er &raquo;</TD></TR><TR><TD CLASS="quote">LIKES IT GOING TO stall OUT.. .. MY FULE PSI IS AT 75.. .. </TD></TR></TABLE>
WTF??????????????? why do you have it at 75 PSI?????? it should be in the low 30"s!
Old Oct 12, 2006 | 02:10 PM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da6er &raquo;</TD></TR><TR><TD CLASS="quote">LIKES IT GOING TO stall OUT.. .. MY FULE PSI IS AT 75.. .. </TD></TR></TABLE> That's why, you might have jacked up your injectors...You should be running at 32 - 35 psi...WTF!
Old Oct 12, 2006 | 08:35 PM
da6er's Avatar
WELL I HAVE CTR PISTIONS WITH THE BLOCK AT A 1.9 IDK THATS JUST HOW THEY BUILT MY MOTOR I GUESS.. ...
Old Oct 13, 2006 | 09:09 PM
da6er's Avatar
Matt2458
Mar 30, 2010 10:45 AM
FJBB6
Oct 12, 2009 05:35 PM
goldenmustache
38
May 13, 2009 07:04 PM
djicon2000si
Dec 16, 2007 11:07 AM
lsvtec95
24
Jun 3, 2007 12:03 AM
