AEM Big Rotor brake kit with 15"
I was wondering if anyone has used the AEM big brake kit. If so does anyone know if you can fit 15" Mugen RNR's over them. I had a friend try them with 15" 5-zigen wheels but they were too small. I measured and it's really close with my wheels.
I know that AEM is not the best for brakes but I would rather go to larger slotted rotors than just stock slotted.
I dont know if they will clear the AEM kit, but Team Dynamics Pro1/(I believe pro2 as well) are the only 15" I know of that will clear the Wilwood 12.2" brake kit. They are the most likely candidate for fitting with AEM brakes. But again, that is simply speculation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4civichatch »</TD></TR><TR><TD CLASS="quote">Just go with a better brake pad and fluid. Your not going to see a gain from slotted rotors, or that AEM kit.</TD></TR></TABLE> I agree. Try a set of better pads and fluid before you dump alot of money on a brake kit you will likely never use to full potential on the street.
