Tranny fluid leak...
Old Oct 11, 2006 | 04:23 PM
Discontained's Avatar
Default Tranny fluid leak...
Ok, im leaking most of my tranny fluid out of the cv axle seal on the tranny. Anybody know what that seal is called ? IS that part replaceable? I just put 2 qt's of MTF in it.. and it all leakd out.
Old Oct 11, 2006 | 06:48 PM
Default Re: Tranny fluid leak... (Discontained)
anyone? Maybe someone has a diagram or something...
haroldthefly91crx's Avatar
yeah you can replace it, just give the year make and model to a parts store and im sure they will help you out and its not that hard to put it
Old Oct 11, 2006 | 06:55 PM
EL Vap133's Avatar
Old Oct 11, 2006 | 06:57 PM
Default Re: Tranny fluid leak... (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Is that #10?
Old Oct 11, 2006 | 07:38 PM
Got_soy's Avatar
i replaced both this summer i think one is 17 and one is 19
Old Oct 11, 2006 | 10:01 PM
Contender25
Guest
Posts: n/a
I said expletive it and put a whole bottle of lucas in my piece of **** dx tranny and keep beating the **** out of it.
Old Oct 11, 2006 | 10:08 PM
Default Re: (Contender25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">I said expletive it and put a whole bottle of lucas in my piece of **** dx tranny and keep beating the **** out of it. </TD></TR></TABLE>
wtf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">i replaced both this summer i think one is 17 and one is 19</TD></TR></TABLE>
Where did you get them at? Advance said they have em for 8 bux a peice
Old Oct 12, 2006 | 07:58 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Discontained)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Discontained &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get them at? Advance said they have em for 8 bux a peice</TD></TR></TABLE>
And there you have it. Just make sure they're the right size.
Old Oct 12, 2006 | 08:00 AM
Got_soy's Avatar
i got them from honda
Old Oct 12, 2006 | 08:43 PM
Contender25
Guest
Posts: n/a
lol wtf?, wtf indeed.....tat **** gone blow up son, hahaha im j/k. I actually did have tranny troubles for a while on it, besides dx trannys long gears are a pity, but i don't really care so i put the WHOLE bottle of lucas in it. The leaking slowed down so much and shifting got so much better and faster that i was like HELL YEAH, lol. Anyways, some of these people say penzoil syncro fluid helps with tranny shifts and leaks, uh no...that **** looks THINNER then conventional oil that your actually suppose to use in honda transmissions, and then actual HTMF, a bottle of it is like 6-7$ from the dealer is a waste because sure it might have slightly better additives in it, but is it really THAT good?, no it's basically the same thickness as oil if not a little better from my eye and point of view. My point of view it lucas in the transmission only, cause if your gonna beat the **** out of it everyday, which i know some of you do, I DO, then just put the whole bottle in there, maybe mix a little oil in with it, it's not gonna effect anything really, cause that **** is so thick you don't even need to replace your seals, lol you do, but im just saying, im not wasting any more money and time on this piece of **** tranny and motor when i could be putting money into a REAL swap.
Old Oct 12, 2006 | 08:49 PM
didyouhearthat's Avatar
Transmission seal: driveshaft (output) seal
Old Oct 13, 2006 | 03:30 AM
gator88's Avatar
Default Re: Tranny fluid leak... (didyouhearthat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">lol wtf?, wtf indeed.....tat **** gone blow up son, hahaha im j/k. I actually did have tranny troubles for a while on it, besides dx trannys long gears are a pity, but i don't really care so i put the WHOLE bottle of lucas in it. The leaking slowed down so much and shifting got so much better and faster that i was like HELL YEAH, lol. Anyways, some of these people say penzoil syncro fluid helps with tranny shifts and leaks, uh no...that **** looks THINNER then conventional oil that your actually suppose to use in honda transmissions, and then actual HTMF, a bottle of it is like 6-7$ from the dealer is a waste because sure it might have slightly better additives in it, but is it really THAT good?, no it's basically the same thickness as oil if not a little better from my eye and point of view. My point of view it lucas in the transmission only, cause if your gonna beat the **** out of it everyday, which i know some of you do, I DO, then just put the whole bottle in there, maybe mix a little oil in with it, it's not gonna effect anything really, cause that **** is so thick you don't even need to replace your seals, lol you do, but im just saying, im not wasting any more money and time on this piece of **** tranny and motor when i could be putting money into a REAL swap. </TD></TR></TABLE>
uh, okay... i wont agree but.. the old "eyeball method of whats thinner and thicker to determine my tranny fluid" trick i never heard of. I just know that i like to fix my problems and be sure im not going to seize a tranny while driving down the highway.
Old Oct 13, 2006 | 02:23 PM
Contender25
Guest
Posts: n/a
Pfft, thats just a saying, "the eyeball point of view" but basically any body knows Lucas IS thicker then penzoil syncromesh, and my **** is so worn out, the lucas totally restored the transmissions life by 50% i would say, just saying.
Excuse my grammar.
Old Oct 13, 2006 | 02:52 PM
gospeedgo1's Avatar
arent there pictures on bobistheoilguy showing how lucas oil foamed up when subjected to high rpm?
read this.
http://www.bobistheoilguy.com/...s.htm
i use gm syncromesh. it helped some which I hoped for. im not expecting it to restore my tranny to when it first rolled off the dealers lot. you have to remember that synthetics are thinner at room temperature when compared to regular dino oil. does that mean that synthetics suck cause they are thinner at room temp?
Old Oct 13, 2006 | 06:23 PM
Contender25
Guest
Posts: n/a
Hmm looks like my tranny is takin it then because that **** shifts fine now, if anything i need to change my little shifter bushing and im set. Btw, lucas IMO is a big no no when it comes to using it in my engine, but i WILL use it in my transmission.
Old Oct 14, 2006 | 10:09 AM
daveb91's Avatar
Your story was good i guess but its a good thing discontinued did the right thing and replaced the gasket. Good job.
Old Oct 14, 2006 | 05:58 PM
Contender25
Guest
Posts: n/a
Idk if he replaced it or not bro, but if he did good for him. I just thought i give you guys my opinion on using the whole bottle of lucas in your tranny, for your info it's fine, obviously..lol.
Old Oct 15, 2006 | 03:26 PM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Discontained &raquo;</TD></TR><TR><TD CLASS="quote">? I just put 2 qt's of MTF in it.. and it all leakd out. </TD></TR></TABLE>
arent honda trannys supposed to use regular motor oil? or is MTF motor oil?
Old Oct 15, 2006 | 03:30 PM
jedubz's Avatar
No mean to thread jack but I have a B-series tranny in my EF and I think it could use some syncromesh or maybe just oil but i dont know where to check/add fluid because it's so crammed, any suggestions?
Old Oct 15, 2006 | 03:36 PM
janz3n's Avatar
Default Re: (jedubz)
umm search?
Old Oct 15, 2006 | 04:41 PM
yea i replaced them.. Got them at honda its doesnt leak at all, and i bought some HONDA MTF
thx #GG
Old Oct 16, 2006 | 02:07 AM
Contender25
Guest
Posts: n/a
If your tranny is hard to shift lately and you know your transmission isn't broken yet, then it's either low or out of fluid. There are two bolts on the passenger side of the car underneath the tranny on the edge, one drains the fluid, while the other one takes a funnel with a little hose to refill it back up.
If you go to autozone, sometimes they have them, sometimes they don't, it's a little blue funnel with this little clear flex hose on the end, it's the 2$ one i believe, not the big fat one thats like 5-10$.
jdmstyleEJ6
12
Apr 2, 2010 08:07 PM
invisible
Mar 11, 2007 09:35 PM
Themouse
Nov 22, 2006 05:10 PM
