shifter hitting exhaust
i just put a new header on my car, and besides a bad gasket between the header and cat, it went ok. the only thing is this, it fit really really tight and now when i shift the bottom of the shifter linkage rubs/clanks the exhaust. anyone know a way to fix this, besides getting a new header and getting it lower. maybe a different shifter, or some way to seperate it?
is it the heatshield thats hitting it? it was the heatshield for me, i removed it and it was good after that.
other wise you could try to modify the hangers to hang the ehxaust a little lower.
well, the thing that makes the exhaust high enough that the shifter hits it, is the header, it bolts up to the cat higher up then the 4-1 i had before. i had to take the heat shield off to bolt the 2 sides together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_005200 »</TD></TR><TR><TD CLASS="quote">Well on my integra, i found out that if you use one rubber bushing to hold the cat-back, it lowers it enough where it doesnt scratch a lot, but lets you drive with ease....</TD></TR></TABLE>
i was reading up on about this subject a few days ago so i knew what i was getting myself into, before i went off and bought my short shifter. and the thing that i hear a lot of people were doing was going and getting tyoe-r shift linkage and shifter, they said that you get a better feeling shift, and it doesn't hit anything.
svtford4x4
Jun 15, 2012 09:36 AM
Frost7177
Jan 17, 2007 09:29 AM
gobblebox59
Jun 7, 2004 06:17 AM
