235's on the EP3 chasis?
Old Oct 11, 2006 | 03:28 PM
Alexlai50's Avatar
Default 235's on the EP3 chasis?
Hi Guys,
Looking to buy a set of alloys, really like a set of Enkei's which came off the evo 8 which are 235's
Do you think the wheels will rub?, the rims are 5 stud fitment and pretty sure they fit stud wise...
The car is a Honda Civic Sport 1.6 vtec, totally standard...not lowered or anything
Thanks!!
Alex
Old Oct 11, 2006 | 05:17 PM
fventura03's Avatar
if its not lowered, it should be fine, it'd probably rub when doing U-turns though
Old Oct 11, 2006 | 05:34 PM
Vantage's Avatar
U need to know more than just 5 bolt, figure out offset/width of rim/which 5 bolt pattern is it? how tall is the tire? ... and correct forum is nice,
this is the 2001-2005 non ep3.
Old Oct 11, 2006 | 06:31 PM
Todd00's Avatar
I said I don't want a title!
Default Re: 235's on the EP3 chasis? (Alexlai50)
What's the body style of the car? Coupe, hatch or sedan? You said Ep3, but then you mention a 1.6 vtec sport, so maybe you're in the UK?
Old Oct 11, 2006 | 08:35 PM
toyomatt84's Avatar
Sanji
Default Re: 235's on the EP3 chasis? (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">What's the body style of the car? Coupe, hatch or sedan? You said Ep3, but then you mention a 1.6 vtec sport, so maybe you're in the UK?</TD></TR></TABLE>
The 1.6 VTEC sport is an EP3, bud.
Without lowering the car, the 235's will fit, but if the car were lowered, forget about it.
Old Oct 12, 2006 | 03:10 AM
Alexlai50's Avatar
Sorry for the wrong forum guys!
the rims are
235/40/ZR17 90W
The stud pattern is 5...anyone know if the evo 8 are the same size as the Civic?
The car is a UK spec EP3 Sport....
Thank you very much!!
Old Oct 12, 2006 | 04:03 AM
fventura03's Avatar
if you're not dropped, offset won't matter.
Old Oct 12, 2006 | 03:19 PM
Andrey's Avatar
it is ep2
Old Oct 12, 2006 | 06:25 PM
cnyej1's Avatar
Default Re: (Alexlai50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexlai50 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the wrong forum guys!
the rims are
235/40/ZR17 90W
Thank you very much!! </TD></TR></TABLE>
If its a 1.6 then its an ep2.
Old Oct 12, 2006 | 09:01 PM
BarracksSi's Avatar
EP2, whatever -- it's an EP chassis.
235/40-17 does fit on a +45 offset rim. I'm close to getting a set myself.
Old Oct 13, 2006 | 05:40 AM
cnyej1's Avatar
Default Re: (BarracksSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">EP2, whatever -- it's an EP chassis.
235/40-17 does fit on a +45 offset rim. I'm close to getting a set myself.</TD></TR></TABLE>
Can you make a full turn with it? I thought when the wheel was turned all the way to one side that it would rub.
Old Oct 13, 2006 | 10:14 AM
BarracksSi's Avatar
Default Re: (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Can you make a full turn with it? I thought when the wheel was turned all the way to one side that it would rub.</TD></TR></TABLE>
Technyne over at ephatch has a set of 17" +45 Rota Torques (Work Emotion copy) with 235/40-17's on them and, I think, says that they don't rub.
The sneaky thing is that the larger wheel diameter leaves more room for suspension clearance, like with the trailing arm in the rear.
Of course, you could go with wider in front than in the rear, too. The front needs more traction anyway, and even though you won't be able to rotate tires front-to-rear, you won't be replacing tires any more often, either.
Old Oct 13, 2006 | 11:41 AM
cnyej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">Technyne over at ephatch has a set of 17" +45 Rota Torques (Work Emotion copy) with 235/40-17's on them and, I think, says that they don't rub.
Of course, you could go with wider in front than in the rear, too. The front needs more traction anyway, and even though you won't be able to rotate tires front-to-rear, you won't be replacing tires any more often, either.</TD></TR></TABLE>
I forgot he had those. My mistake.
94coupeNA
21
Mar 23, 2007 03:20 PM
Adamlx
Nov 4, 2006 11:36 AM
uvamosk
Sep 5, 2006 03:41 PM
GSR4D
10
Feb 15, 2005 09:31 AM
Suzukablue
24
Jan 18, 2005 06:39 AM
