HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE
Old Oct 11, 2006 | 11:49 AM
hybridef's Avatar
Default HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE
i have a jdm dohc zc... and im wondering if anyone knows the timing belt that im looking for.. and if im just suppose to look for a zc belt?? and if places like canadian tire, or the ordinary parts places like napa would carry it?? any input would be greatly appreciated, thanks
Old Oct 11, 2006 | 12:22 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE (hybridef)
88 Prelude 2.0 Si belt .
Old Oct 11, 2006 | 12:29 PM
hybridef's Avatar
Default Re: HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE (wiZCo)
you forsure on this one? anyone else have any input
Old Oct 11, 2006 | 12:43 PM
90_civic_Si's Avatar
Thats the belt you need. I would get it from Honda though.
Old Oct 11, 2006 | 01:13 PM
C_R_X_V_T_E_C's Avatar
Default Re: HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE (90_civic_Si)
as long as you ask for the 88 prelude 2.0 Si belt it shouldnt matter where you get it from. in my dealings with honda, EVERYTHING is more expensive and is about the same quality as napa, autozone, advance ect...
Old Oct 11, 2006 | 07:42 PM
hybridef's Avatar
Default Re: HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE (C_R_X_V_T_E_C)
perfect...greatly appreciated
Old Oct 11, 2006 | 07:46 PM
pandarex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">as long as you ask for the 88 prelude 2.0 Si belt it shouldnt matter where you get it from. in my dealings with honda, EVERYTHING is more expensive and is about the same quality as napa, autozone, advance ect...</TD></TR></TABLE>
honda is much better quality, a good ol eye test cant tell the difference, always buy oem if possible. dont go cheap on a timing belt, if it rips it will destroy your engine
Old Oct 11, 2006 | 08:59 PM
hybridef's Avatar
Default Re: HELP... LOOKING FOR TIMINGBELT IN CANADA FOR A JAPANESE ENGINE (pandarex)
what about the tensioner and water pump?? 88 prelude si? all the same shyt?
Old Oct 11, 2006 | 09:05 PM
Tippyman's Avatar
Other Parts / Numbers can be used on ZC:
Timing Belt:-----1988 Prelude 2.0-----14400-PK2-004
Timing Belt Cover:
AC Compressor / Parts:-----1989-91 CRX/Civic-----N/A
AC Bracket:-----1988-91 CRX/Civic-----N/A
...The AC Compressor bracket bolts onto the ZC block.
Throttle Body:-----1988-91 CRX/Civic Si-----N/A
ECU:-----1989-91 CRX/Civic Si-----N/A
ECU:-----1986-89 Integra-----N/A
ECU:-----1989-1991 ZC-----N/A
Intake:-----1988-91 CRX/Civic-----N/A
Headers:-----1986-89 Integra-----Any Kind
Headers:-----1988-1991 CRX/Civic-----N/A
Plug Wires:-----1986-89 Integra-----Any Kind
Spark plugs:-----1986-89 Integra----- NGK BCPR6E-11
Distributor Cap:-----88-91 CRX/Civic-----N/A
Distributor Rotor:-----88-91 CRX/Civic-----N/A
Distributor Cap:-----1988 Integra-----30102-PM7-305
Distributor Rotor:-----1988 Integra-----30103-PM5-A05
Head Gasket:-----1988 Prelude-----12251-PM7-003
Intake Gasket:-----1988 Integra-----17105-PG6-S00
Exhaust Gasket:-----1988 Integra-----18110-PG6-003
Water Pump:-----1990 CRX-----19200-P01-004
Oil Filter:-----1988 Integra-----15400-PR3-004
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic-----N/A
Oil Pan Gasket:-----1986-89 Integra-----N/A
ZC Pressure Plate:-----1989 Civic DX-----N/A
ZC Clutch Disk:-----1989 Civic DX-----22200-PM7-J02
Clutch:-----1990 CRX-----N/A
Old Oct 12, 2006 | 12:52 AM
hybridef's Avatar
Default Re: (Tippyman)
now should i be grabbin the 88 prelude tensioner aswell??
Old Oct 12, 2006 | 09:37 AM
hybridef's Avatar
Default Re: (hybridef)
up
Old Oct 12, 2006 | 10:43 AM
wiZCo's Avatar
Stouts 'n' Scotch
Honda part #: OEM part # 14510-PM7-004. I forget if it's from an Integra (I'm pretty sure it is), I had this done about a year ago and this is what was on my receipt. If you don't want to get OEM, call a dealership to see wht model this comes from then source it through your local auto parts store. Good luck . Also, check out http://www.thezcr.com, it has all the ZC info you need.
Old Oct 12, 2006 | 12:38 PM
jlicrx's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Honda part #: OEM part # 14510-PM7-004. I forget if it's from an Integra (I'm pretty sure it is), I had this done about a year ago and this is what was on my receipt. If you don't want to get OEM, call a dealership to see wht model this comes from then source it through your local auto parts store. Good luck . Also, check out http://www.thezcr.com, it has all the ZC info you need.</TD></TR></TABLE>
tensioner is from 88-91 CRX/Civic Si D16A6 - OEM part # 14510-PM7-004 - as a general rule of thumb, except for the timing belt and gears, everything below the top of the block is the same as the 88-91 CRX/Civic Si D16A6 and everything above the top of the block is the same as the 88-89 Integra D16A1
Old Oct 12, 2006 | 12:44 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Other Parts / Numbers can be used on ZC:
Timing Belt Cover:
Clutch:-----1990 CRX-----N/A</TD></TR></TABLE>
there are several mistakes in that list - for example, the head gasket is from 88-89 Integra, not Prelude - spark plug wires for 86-87 Integra are not the same as for 88-89 Integra - there are more - i would disregard that list entirely
Old Oct 13, 2006 | 10:10 PM
hybridef's Avatar
Default Re: (jlicrx)
appreciate all the help.... did some searching on the zc websites... and just to maybe help clarify some shyt for others ill post up a link i found
http://www.thezcr.com/forums/s...12262
once again thanks for the input
ZCMeGone
Jun 25, 2007 08:02 AM
crxzcracer
Mar 29, 2004 05:23 AM
2point6
Jan 21, 2003 03:34 PM
1990hondaHF
Jul 18, 2002 06:42 AM
Hondasaurs
Jan 24, 2002 11:06 AM
