Differences in USDM ATTS ECU and JDM TYPE-S ATTS ECU
Old Oct 11, 2006 | 11:37 AM
Revi's Avatar
Default Differences in USDM ATTS ECU and JDM TYPE-S ATTS ECU
Are there any differences in between the USDM ATTS ECU and the JDM Type-S ATTS ECU? I somebody else out there has a Type-S ATTS ECU what is the serial number on it? I would like to see if it matches my USDM ATTS ECU.
Old Oct 11, 2006 | 11:38 AM
WhiteBB2's Avatar
Default Re: Differences in USDM ATTS ECU and JDM TYPE-S ATTS ECU (Revi-Ra)
i dont think there are any differences at all other than the jdm one prolly has a governor on it.
Old Oct 11, 2006 | 03:13 PM
Revi's Avatar
Default Re: Differences in USDM ATTS ECU and JDM TYPE-S ATTS ECU (WhiteBB2)
The governor is problably on the JDM Main ECU in talking about the ATTS ECUs. Im getting about 10 ATTS codes wich ive had since the swap. One is for the Map sensor another for he PGMFI. I trying to figure out if the ATTS ECU is reading different numbers from the JDM ECU and its sensors throwing it out of wack. I could alwasy swap my spare good known ATTS unit in my garage but i dont want to waste my time if i dont have too.
Old Oct 11, 2006 | 03:15 PM
WhiteBB2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">The governor is problably on the JDM Main ECU in talking about the ATTS ECUs </TD></TR></TABLE>
you are right, ignore my last post. sry
pkolaboy
Apr 15, 2008 08:31 PM
Project.Jdm
Jan 8, 2008 10:48 AM
Nims
Jan 15, 2006 01:18 AM
