compresion test on a stock gsr
i need to know when you do a compression test on a stock gsr what should the psi be.mine threw 212-214 on all 4.if thats not stock i would like to kno what whats my compression to see it i go on spray or boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">Those numbers are good. </TD></TR></TABLE>
yeah they are good, they should all be real close to the same compression.
Good CR numbers. They're in the range of a healthy engine, and all 4 are very close together to boot. A range of 28psi between the cylinders is allowed to be considered a healthy engine.
Rtboy10
Sep 21, 2009 03:12 PM
