Can DC2 tail lights be opened up?? (Taking the lense cover off)
Old Oct 11, 2006 | 09:21 AM
jonshonda's Avatar
Community Builder
Default Can DC2 tail lights be opened up?? (Taking the lense cover off)
Hello all, I am wanting to to tint my Dc2 Tail lights. But I would like to tint them from the inside for a cleaner look. I know that you can stick the headlights in the oven and open them up, but can you do the same to the tail lights. First hand knowledge would be great> TIA
Old Oct 11, 2006 | 09:41 AM
copsloveme's Avatar
Default Re: Can DC2 tail lights be opened up?? (jonshonda)
you can do the oven thing w/ the rear tail lights but its extremely easy to expletive it up. if u do end up doing it, do it as slooowly as you can (pulling the outer plastic from the housing).
since the bitch is off might as well make em into JDM style tails (if you have 94-97 tail lights)
resealing is a diff story
Old Oct 11, 2006 | 09:51 AM
-Championship-'s Avatar
76.169.175.137
Default Re: Can DC2 tail lights be opened up?? (copsloveme)
yes you can, are you really going to want to tint them?...i would stick with oem
Old Oct 11, 2006 | 03:44 PM
S1NFUL RL1 619's Avatar
Default Re: Can DC2 tail lights be opened up?? (CW_98gsr)
wouldn't it be hard to tint them from the inside? i thought the surface isn't flat on the inside? maybe i'm wrong.
but in terms of opening them up, don't throw them in the oven, use a heat gun. it's easier to know when to pull the plastic pieces apart because you can feel the plastic melting. use a good pair of gloves while you're doing it too. and when you're ready to seal them up, just melt the assembly like you did when you took it apart, but when it's all together, then make sure you have some liquid silicon to seal it up so you don't get any fogging or leaking.
Old Oct 11, 2006 | 07:19 PM
jonshonda's Avatar
Community Builder
I don't know how hard it is going to be to tint the inside, I searched the topic but didn't find anything, and I want to tint the tails cuz I think it will look good with my black teg. I really dont want to tint the outside because it never looks oem, and rarely turns out the way I would like. just thought I would try an alternative to tinting the outside
Old Oct 12, 2006 | 09:32 AM
jonshonda's Avatar
Community Builder
Anyone ever done this b4??
Old Oct 12, 2006 | 09:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You can't tint the inside with a film, you would have to use a spray can. The inside has the prismatic surface that spreads out the light from the bulbs.
Those who said it can be opened up with heat, are you sure about that? Have you done it before? I tried using heat to open my front bumper lenses, but they seem to be held together with a hard epoxy, and not a flexible sealant like the headlights. I would have had to cut the bumper lenses apart with a Dremel.
I'm thinking the taillights are the same way.
Old Oct 12, 2006 | 09:51 AM
98GSRDC2's Avatar
yes its possible, but tinting them? are you sure?
Old Oct 12, 2006 | 02:55 PM
jonshonda's Avatar
Community Builder
I am going to use spray tint, and I think it will work out alright. We will have to see. I would rather try to tint them from the inside, for the clean look
Old Oct 12, 2006 | 03:00 PM
bboysake's Avatar
Since we're on the topic of opening up the tail lights is there anyway to keep moisture out etc.?
Old Oct 12, 2006 | 03:26 PM
Community Builder
Default Re: (bboysake)
I ran a bead of silicone along the top edge of my taillight lenses. Water was getting in through there and flooding my trunk, but it's all good now.
Old Oct 16, 2006 | 06:54 AM
jonshonda's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboysake &raquo;</TD></TR><TR><TD CLASS="quote">Since we're on the topic of opening up the tail lights is there anyway to keep moisture out etc.?</TD></TR></TABLE>
Quit thread jacking fool.. I would like FIRST HAND KNOWLEDGE PLEASE..
Old Oct 17, 2006 | 08:53 AM
jonshonda's Avatar
Community Builder
Everyone says it can be done, but after looking at the tail light I don't know if it is such a good idea.
Doubledeala
Honda S2000
17
Nov 18, 2004 07:58 PM
