oem honda oil filters?????
i read this on inlinefour's website :
TIP: If you want a bit more oil pressure, you can use the RSX/01Civic filters on your B-series engine. We've noticed an increase in oil pressure and less fluctuation during VTEC operation.
just wanted to know if anybody had tryed this and seen a change in oil preasure???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 »</TD></TR><TR><TD CLASS="quote">i use fram, but thinking of going with the smaller oem honda filter..</TD></TR></TABLE>
Bad idea!!! Fram sucks for mutiple reasons. Here check this out and you will see why. Fram filters will never see another one of my cars. http://www.bobistheoilguy.com/
There has been a lot of talk about this subject, it all started with the s2000 filters. Then honda changed the size to a smaller filter for just about everything.
You need to be carefull even with oem filters as a lot of them are made bu fram, you can order different part numbers for filters that are not made by fram, but are still oem.
JaredKaragen
Oct 23, 2007 06:04 PM
Sohc Driver
Mar 9, 2004 06:31 AM
