Help with engine issue. Boggin?
Old Oct 10, 2006 | 08:33 PM
antnyc9r1x's Avatar
Default Help with engine issue. Boggin?
Hi everyone. Recently my rex is starting to, hard to explain in words, but i guess its boggin. When I'm cruising on the frwy it sounds like my car is poppin, but more of a low deep popping sound. The whole car jerks like crazy then i let off the gas and gas it again and seems to go away. Then it will come back. I am not sure if its the ignition or the clutch acting up. Does anyone know of possible causes for this. The shop I usually take it to, I can't get a hold of N E 1.
I'm running a B18C1 OBD0 PR3 ECU & S1 Tranny. Runs really rich so I advanced my timing a bit more than usual. I plan on doing a OBD0 to OBD1 and run a P72 ECU. But I need to remedy this issue b4 I buy stuff for the conversion.
Hope you can help. Thanks in advance.
Old Oct 10, 2006 | 08:39 PM
Coltmorris's Avatar
Default Re: Help with engine issue. Boggin? (antnyc9r1x)
have a similar problem cept more serious--hows your car idle? what I would do is just check your plugs and cap and rotor..maybe its a bad injector, im sorta just reiterating the advice i recieved haha
Old Oct 11, 2006 | 08:21 AM
antnyc9r1x's Avatar
Default Re: Help with engine issue. Boggin? (Coltmorris)
My Idle is fine just on occasions it would surge up and down, usually in the morning. I checked the cap and rotor and it looks fine to me. My plugs are fairly new. I'm using nology wires. My injectors are questionable. I may turn to OBD1 injectors, but maybe i should just get new 330cc from RC. My fuel pump is the stock DX. Will this cause the bogging? I know I should put a better one like a walbro 190, Ive heard the 220's are a bit noisy.
Old Oct 11, 2006 | 08:37 AM
89 civic si's Avatar
check the distributor wiring did you have to convert to mpfi? check the fuel filter try putting fresh gas into it
Old Oct 11, 2006 | 10:02 AM
crx_88_si's Avatar
b18c1 running off a PR3!
there's your problem.
Old Oct 16, 2006 | 12:54 PM
antnyc9r1x's Avatar
Default Re: (crx_88_si)
Well, Hopefully that converting to OBD1 will eliminate the boggin. The guys that did my swap, I guess, went the easy route of OBD0. I am staring to purchase everything I need for the OBD1 conversion.
DAman9
Aug 5, 2013 07:17 PM
xsi90teg
Feb 23, 2009 05:26 PM
gsrpowercrx
Jan 18, 2009 02:51 PM
honda_ek9
Engine Management and Tuning
13
Jan 8, 2009 09:06 PM
