2001 Accord ex timing belt/balance shaft belt
Old Oct 10, 2006 | 08:16 PM
Obd 1uan's Avatar
Default 2001 Accord ex timing belt/balance shaft belt
I just wanted to know if anyone had a link to a diy site where it shows how to re-install the timing belt/balanceshaft belt properly. I have tried to put the belts back on about 5 times using the helms manual but I could tell every time i shoot the pulley bolt back on, the balance shaft timing goes off as i could feel major vibration in the cabin. Ive done the following: set timing belt at tdc, then i put the 6*100 bolt in the service rear balance shaft hole. i then lined the front balance shaft to the mark on the block and reinstall belt. Is there anything im missing?? thanks.
Old Oct 11, 2006 | 12:11 AM
Chiovnidca's Avatar
Default Re: 2001 Accord ex timing belt/balance shaft belt (Obd 1uan)
There's three possitions the 6x100 bolt will go in. The easiest way to line it up right is to spin it by hand to where it moves into possition by itself and the service bolt is very close to lining up. Play with it, you'll see.
Old Oct 11, 2006 | 11:17 AM
Obd 1uan's Avatar
i was reading on the helms manual also that im not suppose to use any air tools to put the crankshaft pulley bolt back on. Is that something you guys have heard of ???
Old Oct 13, 2006 | 05:42 PM
swapped95's Avatar
did anyone have a link to the diy on the timing belt install??? 01 accord 4cyl.
Old Oct 13, 2006 | 07:56 PM
rollercosta123's Avatar
Default Re: (swapped95)
remove a 12mm bolt in the back near the rear oil shaft and stick it a alan key that can keep it from moveing. dont forget to remove it when your done
Old Oct 26, 2006 | 05:44 PM
Obd 1uan's Avatar
im going to tear the car down once again. Just want to double check see if i am missing anything.
- I need to align the pointer on the crankshaft pulley to the mark on the block.
- I need to have camshaft sprocket mark facing the 9'o clock position, so it faces the surface of head.
- I then put timing belt on.
- Align front balance shaft mark to mark on the block (facing 12' o clock)
- Align rear shaft by inserting a 6*100 allen wrench.
- Crankshaft pulley should still be at tdc, so i then place belt on.
- tighten down tensioner bolt and tighten crankshaft bolt.
Let me know if i missed something. thanks
Old Oct 27, 2006 | 02:46 PM
Obd 1uan's Avatar
bump
Old Oct 27, 2006 | 09:36 PM
hondadude's Avatar
This link shows how the rear balance shaft pulley should be aligned; Sticking the pin thru the shaft you could be 180* out. it should have a 'natural' fall or turn to the correct position. There is a dot on the pulley that lines up with a casting boss.
http://members.troublecodes.ne...t.htm
danewickenhauser
Jul 25, 2009 04:38 PM
jay24k
Nov 16, 2008 08:12 PM
danz75
Jun 29, 2004 10:52 PM
SpoolinEK
Dec 17, 2003 05:39 PM
baonest1
Jun 10, 2003 04:03 PM
