how many ft. lbs. of torque...
wat up?...i got a 90 crx si n i need help... how many ft. lbs. of torque should i torque down my d16a6 head to the block?...plz let me kno or let me kno where 2 find the info...thanx n hope u can help.
Modified by jdm crx guzman at 7:48 PM 10/10/2006
ok first get new head studs spray the gasket with copper spray then start in the center tourque to 26 ft lb then go back start in the center and tourque to 68fl lbs then your can is 22 ft lbs and your valve ajestment should be .006-.007 you know how to do that right and you need a 10 mm tool for that but make sure your head gasket is good and sticky when you put it on and try to put the guides on the block and not the head to prevent the gasket from sliding around and ruining it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm crx guzman »</TD></TR><TR><TD CLASS="quote">wat up?...i got a 90 crx si n i need help... how many ft. lbs. of torque should i torque down my d16a6 head to the block?...plz let me kno or let me kno where 2 find the info...thanx n hope u can help.</TD></TR></TABLE>
http://www.helminc.com/helm/pr...075B4
blackccoupe
Aug 27, 2008 07:23 PM
bigizsosexy
Apr 30, 2008 10:38 AM
jonathan116
14
Jan 11, 2006 04:21 PM
