SEARCHED!!! Sir-G Fog light switch install
I have the ITR front end and my fogs are hooked up to my parking lights. I have a switch that I want to use for the fogs but not sure how to hook it up. It came with the connector and there are 3 stands of wire off it. I know it sounds fairly simple but I'm not too good with electrical stuff. It took me 2hrs to figure out how to wire up the fogs to my parking lights and a couple of fuses.
Thanks H-T...
Thanks H-T...
Well on my DC2, i put the orignal fog light switch that replaces the Cruise Control switch. The wiring I bought at Pep Boys, it gives you the wires, the relay (very very important part) and a switch. Follow the instructions as given on the kit. If you want you car to look orignal in the inside, you have to scrafice your cruise control. First use a test light to find out what is the power up the relay when the switch is on. Once you find that out, cut the wire and contact it to the postive end of the switch that comes in the package, and the negative with the black wire on the harnass. if you need any more help, just let me know
